Add a LCD panel (ST7701 controller) on linux 5.4.47 with i.MX8M mini
已解决
跳至解决方案
2,273 次查看
Hardevsinh_Palaniya
I tried to add a new panel in i.MX8M Mini with ST7701 controller on Yocto kernel 5.4.47. I got error "imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi"
After that probe completed successfully with sending init sequence. I can also confirm fbset on board, but can not see anything on display.
Can you please guide me how to solve the issue?
Any help will be appreciated.
Senior Embedded Engineer | hardevsinh.palaniya@siliconsignals.io | www.siliconsignals.io
1 解答
2,245 次查看
Hardevsinh_Palaniya
Thanks for your reply. My problem is already solved.
I follow the link bellow and replace driver with @fangkai 's   driver.
https://community.nxp.com/t5/i-MX-Processors/how-to-add-a-new-panel-with-imx8mm-evk-I-got-some-probl...
With above link and minor changes, My LCD panel worked.
在原帖中查看解决方案
3 回复数
2,254 次查看
Zhiming_Liu
Hi @Hardevsinh_Palaniya
Can you share your dts changes?
2,246 次查看
Hardevsinh_Palaniya
2,267 次查看
Hardevsinh_Palaniya
Can somebody assist me with this?
