Update kernel partition
1,194件の閲覧回数
patrick-olivier
So I've some difficulties getting my kernel partition up to date whitout a manual intervention.
Right now, I'm using kernel 3.12.10 with i.mx28 and a NAND.
I can boot successfully after programming my device with MFGTools, but I can't reprogram my partition when I'm in the field. Technically, it should be possible because I'm running in RAM..
When I use kobs-ng, I get these errors :
0x8050800F
0x80508008
It seem to be an ECC failed - data is not valid, but I can't explain why..
Any suggestions to fix this error ?
0 返答(返信)
