UUC source code and initramfs
ソリューションへジャンプ
7,340件の閲覧回数
emilmyhrman
I'm trying to find the source code for UUC for creating an intramfs for MFGTool, does anyone here know where it is found?
Also, I can't find any information on how to build the initramfs that is used by MFGTool, is there any special requirements for it? Could the recovery.img from Android build be used (assuming UUC binary is included in it)?
ラベル(2)
6,172件の閲覧回数
PeterChan
Hello Emil,
You can run the following command to get the UUC source code.
./ltib -m prep -p uuc.spec
The initramfs image can be generated by running "./ltib -m config" and choose "initramfs" at "Target Image Generation".
--- Target Image Generation
   Options --->
        --- Choose your root filesystem image type
        Target image: (initramfs) --->
Peter
7 返答(返信)
6,172件の閲覧回数
emilmyhrman
Thanks for the help. Was unable to build ltib on ubuntu, but I found the uuc source so that's fine.
6,172件の閲覧回数
xixiguohan
Hi Emil,
Could you share me how to customize my own initramfs that can be used by MFGTool?
Best Regards
xixiguo
6,172件の閲覧回数
emilmyhrman
I believe there is a build target when using Yocto that will build the root filesystem used by MfgTool. I don't remember what it's called, you could search/ask the community here and someone probably knows.
Some starting points I found:
https://community.nxp.com/thread/384595
Freescale Yocto Project main page
FSL Community BSP
good luck :smileyhappy:
6,172件の閲覧回数
xixiguohan
Thank you Emil, I have solved my problem. I got the uuc source code from github. I customized my own rootfs. It works well.
Best Regards
xixiguo
6,172件の閲覧回数
georgereimer
That's great. Would you mind sharing with us where you found it?
thankx
6,172件の閲覧回数
emilmyhrman
6,173件の閲覧回数
PeterChan
Hello Emil,
   Options --->
Peter
