Hi chen
first I would highly suggest to move to more new kernel,
since it has better memory management
L2.6.31_09.12.00_SDK_SOURCE
: Linux 2.6.31 Source Code
Second from log seems that this may be caused also by hardware, since
big size data transfer causes big noise on system, so additionally I would suggest to
test memory. Just for testing you may wish to decrease operating frequency (procesor and
memory) and test if issue will persist. Probably you can change memory stick, use
well known vendor.
