I am working with Phytec imx6ul board. It comes with barebox on it.
I cannot detect USB stick from barebox using usb and detect commands. No USB device is found after probing
I have the same config for USB host, USB mass storage and filesystem support as in Linux.
But after the kernel is loading, it detects successfully the USB devices from Linux.
What could be the issue with barebox?
Also barebox usb config does not offer the possibility to enable some sort of USB debug.
Mihaita
