USB OTG debug cable driver failed(imx8mq evk board)
2,558件の閲覧回数
octmejun123
i just got a new IMX8MQ evk board and i wanted to flash the linxu via usb debug table. however, the os device mangager couldn't recognize the cable(debug USB pin) even i installed the VCP driver. could you raise your ideas? thanks .
2,540件の閲覧回数
DeahyunKim
When the board is powered on, the USB will be detected.
