UART3 can't work in 3.5.7 kernel
kenwu
I need to use uart3 for my bluetooth module, by default, I can't find /dev/ttymxc2 when system boot up, after look into 3.5.7 kernel and modify device tree structure at ~/arch/arm/boot/dts/imx6qdl-sabreauto.dtsi and ~/arch/arm/boot/dts/imx6q.dtsi, now I have /dev/ttymxc2.
But unfortunately, it can't work.
I want to know if I still miss any modificatioin to enable this UART3, please help, thanks.
PS. my platform is i.MX6 base board with SABRE for automotive infotainment cpu board, uart3 interface is on i.MX6 base board
Thanks in advanced
Ken
alejandrolozan1
Hi Ken,
Can you notify this in the meta-freescale mailing list?
https://lists.yoctoproject.org/listinfo/meta-freescale
Alejandro
kenwu
Yes, I can see that, will register now.
Ken
LeonardoSandova
Specialist I
Ken, have you tried the same setup on 3.10.17?
kenwu
I am sure that 3.10.9 works fine with UART3 (/dev/ttymxc2), we don’t try on 3.10.17.
In this release, it don’t provide 3.10.17.bb.
Ken
