Tutorial for Soong Build System
5,017 次查看
JK-IMX
Contributor V
Hi NXP champs
Can you please point a tutorial or guidance for Android Soong Build system?
James
5,003 次查看
Bio_TICFSL
Hello James,
There is no document fo Soong you have to check the webpage officially:
https://source.android.com/docs/setup/build
4,999 次查看
JK-IMX
Contributor V
Thanks.
5,004 次查看
Bio_TICFSL
Hello James,
4,982 次查看
JK-IMX
Contributor V
Provided customer with Android Developer Guide written by NXP. It's accepted as it describes the adding a new driver based on GKI based Android 12 version.
