On imx93, my Goal is to comeup with an application that can run a vela model on ethosu65. I am able to build a linux image with ML examples and run the same(label_image) on A55 and on ethosu65.
im interested in finding source code for label_image application but not able to find any source code in yocto build directory
Thanks for the prompt response.
github points to the python code, I'm more interested in finding c/c++ source code that invokes ethos driver.
so that I can experiment, modify and recompile and copy it to rootfs
I'm following build procedure mentioned in
