Tracing Hardware Fault
MAUZ
I am using MINXRT1064 with multi threaded code using azure rtos. After running for some time I get a hardware fault (I have a break point in HardFault_Handler() function).
Is there a way to trace what condition cased this and what was the function that resulted in hardware fault
jeremyzhou
To provide the fastest possible support, I'd highly recommend you refer to the application note to figure out the cause of the hardfault interrupt.
TIC
jeremyzhou
TIC
