Tracing Hardware Fault
1,883件の閲覧回数
MAUZ
I am using MINXRT1064 with multi threaded code using azure rtos. After running for some time I get a hardware fault (I have a break point in HardFault_Handler() function).
Is there a way to trace what condition cased this and what was the function that resulted in hardware fault
1,879件の閲覧回数
jeremyzhou
To provide the fastest possible support, I'd highly recommend you refer to the application note to figure out the cause of the hardfault interrupt.
TIC
1,880件の閲覧回数
jeremyzhou
TIC
