Touchscreen Driver not working , GT9271 chip connected nxp-imx93frdm PCAL6524 gpio expander
2,375件の閲覧回数
DharmikVelamala
Hello NXP Team,
We are integrating a Goodix GT9271 touchscreen with the i.MX93 EVK board using the MIPI-DSI interface. The touch interrupt (INT) and reset (RST) signals are routed via the I/O expander PCAL6524HEAZ (I2C address 0x22, connected on I2C1).
System Details:
  • Board: i.MX93 EVK
  • Processor: i.MX9352
  • Linux Version: 6.6.36-lts-next (Yocto Scarthgap 6.6)
  • Display Interface: MIPI-DSI
  • Touch Controller: Goodix GT9271 (I2C addr: 0x5D)
  • I/O Expander: NXP PCAL6524HEAZ (I2C addr: 0x22)
  • GT9xx Driver Version: V2.8.0.2 (custom driver integration)
Hardware Pin Mapping (from EVK schematic):
  • MIPI-DSI connector (P7):
    • Pin 17 → CTP_RST → U725.P2_1 (GPIO17 on PCAL6524)
    • Pin 18 → DSI_CTP_nINT → U725.P0_7 (GPIO7 on PCAL6524)
Debug messages from nxp board:
gpiochip4: GPIOs 640-663, parent: i2c/1-0022, 1-0022, can sleep:
[ 9475.945028] Gt9xx driver exited
[ 9477.986387] Gt9xx driver installing..
[ 9477.986597] goodix-custom 2-005d: GTP Driver Version: V2.8.0.2<2017/12/14>
[ 9477.986609] goodix-custom 2-005d: GTP I2C Address: 0x5d
[ 9477.986636] goodix-custom 2-005d: vdd_ana regulator not found, using dummy
[ 9477.986642] goodix-custom 2-005d: vcc_i2c regulator not found, using dummy
[ 9477.986646] goodix-custom 2-005d: Guitar reset
[ 9478.016950] goodix-custom 2-005d: I2C Addr is 5d
[ 9478.017220] goodix-custom 2-005d: IC Version: 9271_1020
[ 9478.017498] goodix-custom 2-005d: Driver set not send config
[ 9478.023312] goodix-custom 2-005d: Use slot report protocol
[ 9478.023488] input: goodix-ts as /devices/virtual/input/input7
[ 9478.024381] goodix-custom 2-005d: INT num -22, trigger type:0
[ 9478.024400] goodix-custom 2-005d: Failed to request irq -22
[ 9478.024404] goodix-custom 2-005d: Failed create work thread
[ 9478.042299] goodix-custom: probe of 2-005d failed with error -22
I am creating ".ko" file and inserting into the imx 93frdm board by using command insmod and manually assigning 0x5d i2c to goodix-custom module there is some run time error, and I can't insert the module can you help me with this
3 返答(返信)
2,271件の閲覧回数
DharmikVelamala
Hello NXP Community,
I am currently working on integrating a Goodix touchscreen (GT9271) with the i.MX93FRDM BOARD. The touchscreen uses I2C address 0x5D, and both the interrupt (INT) and reset (RST) lines are routed through an I/O expander PCAL6524HEAZ (U725), which is located at I2C address 0x22.
According to the hardware schematic:
  • CTP_INT (Interrupt) is connected to P0_7 on U725.
  • CTP_RST (Reset) is connected to P2_1 on U725.
  • These pins are exposed via the 22-pin MIPI DSI FPC connector as:
    • Pin 18: DSI_CTP_nINT (P0_7)
    • Pin 17: CTP_RST (P2_1)
When I inspect the GPIO base via /sys/kernel/debug/gpio, I get:
This confirms that the base GPIO number for PCAL6524 is 640.
Based on this, I mapped the pins as:
  • P0_7 = 640 + 7 = GPIO 647
  • P2_1 = 640 + 16 (P2 base offset) + 1 = GPIO 657
I hardcoded these values in my Goodix driver as:
#define GTP_INT_PORT 647 #define GTP_RST_PORT 657
The driver loads and probes the I2C address correctly. However, when it attempts to request an IRQ, I get the following error:
[ 2385.431060] goodix-custom 2-005d: INT num -22, trigger type:0
[ 2385.431080] goodix-custom 2-005d: Failed to request irq -22
This indicates that gpio_to_irq() is returning an invalid IRQ number (-22 = EINVAL).
My questions are:
  1. Are GPIOs 647 and 657 the correct numbers for P0_7 and P2_1 of the PCAL6524 expander on i.MX93?
  2. Do I need to configure anything specific in the device tree, pinctrl, or elsewhere to properly export these expander GPIOs for interrupt usage?
  3. Is there a recommended method by NXP to use GPIO interrupts from PCAL6524 in custom drivers such as this touchscreen driver?
Any clarification or examples on using PCAL6524 GPIOs as interrupt lines on the i.MX93 platform would be very helpful.
Thank you in advance for your support.
2,364件の閲覧回数
Bio_TICFSL
Looks like device not responding when you entered the module please check it, and check if the module is build again the kernel version you are using, and also check the device tree is possible that you don't have it.
2,318件の閲覧回数
DharmikVelamala
I am currently working on integrating a Goodix touchscreen (GT9xx series) with the i.MX93 platform. The touchscreen uses I2C address 0x5D, and both the interrupt (INT) and reset (RST) lines are routed through an I/O expander PCAL6524HEAZ (U725), which is located at I2C address 0x22.
My questions are:
%3CLINGO-SUB%20id%3D%22lingo-sub-2136568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82GT9271%E3%83%81%E3%83%83%E3%83%97%E3%81%8Cnxp-imx93frdm%20PCAL6524%20gpio%E3%82%A8%E3%82%AD%E3%82%B9%E3%83%91%E3%83%B3%E3%83%80%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3EMIPI-DSI%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81Goodix%20GT9271%20%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%92%20i.MX93%20EVK%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%BF%E3%83%83%E3%83%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20(INT)%20%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20(RST)%20%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%80%81%20%3CSTRONG%3EI%2FO%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%91%E3%83%B3%E3%83%80%E3%83%BC%20PCAL6524HEAZ%3C%2FSTRONG%3E%20(I2C%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x22%E3%80%81I2C1%20%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89)%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1972007542%22%20id%3D%22toc-hId-2001443057%22%3E%3CSTRONG%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E8%A9%B3%E7%B4%B0%3C%2FSTRONG%3E%3A%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3A%20i.MX93%20EVK%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FSTRONG%3E%EF%BC%9Ai.MX9352%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ELinux%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSTRONG%3E%3A%206.6.36-lts-next%EF%BC%88%E3%83%A8%E3%82%AF%E3%83%88%E3%83%BB%E3%82%B9%E3%82%AB%E3%83%BC%E3%82%B9%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%206.6%EF%BC%89%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FSTRONG%3E%3A%20MIPI-DSI%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E3%82%BF%E3%83%83%E3%83%81%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FSTRONG%3E%EF%BC%9AGoodix%20GT9271%EF%BC%88I2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%EF%BC%9A0x5D%EF%BC%89%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EI%2FO%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%91%E3%83%B3%E3%83%80%E3%83%BC%3C%2FSTRONG%3E%EF%BC%9ANXP%20PCAL6524HEAZ%EF%BC%88I2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%EF%BC%9A0x22%EF%BC%89%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EGT9xx%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSTRONG%3E%3A%20V2.8.0.2%20(%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E7%B5%B1%E5%90%88)%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-164553079%22%20id%3D%22toc-hId-193988594%22%3E%3CSTRONG%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%94%E3%83%B3%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%3C%2FSTRONG%3E(EVK%20%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%88%E3%82%8A)%3A%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EMIPI-DSI%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%EF%BC%88P7%EF%BC%89%3C%2FSTRONG%3E%20%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E3%83%94%E3%83%B317%20%E2%86%92%20CTP_RST%20%E2%86%92%20U725.P2_1%20(PCAL6524%E3%81%AEGPIO17)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%94%E3%83%B318%20%E2%86%92%20DSI_CTP_nINT%20%E2%86%92%20U725.P0_7%20(PCAL6524%E3%81%AEGPIO7)%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3Enxp%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Egpiochip4%3A%20GPIO%20640-663%E3%80%81%E8%A6%AA%3A%20i2c%2F1-0022%E3%80%811-0022%E3%80%81CAN%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%3A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%5B%209475.945028%5DGt9xx%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%209477.986387%5DGt9xx%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%209477.986597%5D%20goodix-custom%202-005d%3A%20GTP%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%20V2.8.0.2%26lt%3B2017%2F12%2F14%26gt%3B%3CBR%20%2F%3E%20%5B%209477.986609%5D%20goodix-custom%202-005d%3A%20GTP%20I2C%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%200x5d%3CBR%20%2F%3E%20%5B%209477.986636%5D%20goodix-custom%202-005d%3A%20vdd_ana%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%209477.986642%5D%20goodix-custom%202-005d%3A%20vcc_i2c%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%80%E3%83%9F%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B%209477.986646%5D%20goodix-custom%202-005d%3A%20%E3%82%AE%E3%82%BF%E3%83%BC%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3CBR%20%2F%3E%5B%209478.016950%5D%20goodix-custom%202-005d%3A%20I2C%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%205d%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B%209478.017220%5D%20goodix-custom%202-005d%3A%20IC%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%209271_1020%3CBR%20%2F%3E%20%5B%209478.017498%5D%20goodix-custom%202-005d%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%AA%E3%81%84%3CBR%20%2F%3E%5B%209478.023312%5D%20goodix-custom%202-005d%3A%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%209478.023488%5D%20%E5%85%A5%E5%8A%9B%3A%20goodix-ts%20%E3%82%92%20%2Fdevices%2Fvirtual%2Finput%2Finput7%20%E3%81%A8%E3%81%97%E3%81%A6%3CBR%20%2F%3E%5B%209478.024381%5D%20goodix-custom%202-005d%3A%20INT%20num%20-22%E3%80%81%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97%3A0%3CBR%20%2F%3E%20%5B%209478.024400%5D%20goodix-custom%202-005d%3A%20irq%20-22%20%E3%81%AE%E8%A6%81%E6%B1%82%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%209478.024404%5D%20goodix-custom%202-005d%3A%20%E4%BD%9C%E6%A5%ADThread%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%209478.042299%5D%20goodix-custom%3A%202-005d%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-22%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%80%8C.ko%E3%80%8D%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89insmod%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6imx%2093frdm%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%97%E3%80%810x5d%20i2c%E3%82%92goodix-custom%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E6%89%8B%E5%8B%95%E3%81%A7%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%A8%E3%80%81%E5%AE%9F%E8%A1%8C%E6%99%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E6%8C%BF%E5%85%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Touchscreen%20Driver%20not%20working%20%2C%20GT9271%20chip%20connected%20nxp-imx93frdm%20PCAL6524%20gpio%20expander%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81Goodix%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%EF%BC%88GT9271%EF%BC%89%E3%82%92%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Ei.MX93FRDM%20%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%80%82%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x5D%3C%2FSTRONG%3E%20%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%EF%BC%88INT%EF%BC%89%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%EF%BC%88RST%EF%BC%89%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EI%2FO%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%91%E3%83%B3%E3%83%80%E3%83%BC%20PCAL6524HEAZ%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%88U725%EF%BC%89%E3%81%AF%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B90x22%3C%2FSTRONG%3E%20%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3ECTP_INT%EF%BC%88%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%EF%BC%89%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EP0_7%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EU725%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ECTP_RST%EF%BC%88%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%EF%BC%89%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EP2_1%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EU725%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E3%80%8122%20%E3%83%94%E3%83%B3%20MIPI%20DSI%20FPC%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E3%83%94%E3%83%B318%3A%20DSI_CTP_nINT%20(P0_7)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%94%E3%83%B317%3A%20CTP_RST%20(P2_1)%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%2Fsys%2Fkernel%2Fdebug%2Fgpio%20%E7%B5%8C%E7%94%B1%E3%81%A7%20GPIO%20%E3%83%99%E3%83%BC%E3%82%B9%E3%82%92%E8%AA%BF%E3%81%B9%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3Egpiochip4%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20GPIO%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20640%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20-663%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E8%A6%AA%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20i2c%2F1-0022%E3%80%811%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E-0022%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%80%81%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E5%8F%AF%E8%83%BD%3A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EPCAL6524%20%E3%81%AE%E5%9F%BA%E6%9C%AC%20GPIO%20%E7%95%AA%E5%8F%B7%E3%81%AF%20640%20%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%E3%83%94%E3%83%B3%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EP0_7%20%3D%20640%20%2B%207%20%3D%20GPIO%20647%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EP2_1%20%3D%20640%20%2B%2016%20(P2%E3%83%99%E3%83%BC%E3%82%B9%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88)%20%2B%201%20%3D%20GPIO%20657%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%A7%81%E3%81%AF%20Goodix%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%80%A4%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%23GTP_INT_PORT%20647%3CSPAN%20class%3D%22%22%3E%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%23GTP_RST_PORT%20657%3CSPAN%20class%3D%22%22%3E%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%20I2C%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81IRQ%20%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%5B%20%3CSPAN%20class%3D%22%22%3E2385.431060%3C%2FSPAN%3E%20%5D%3CSPAN%20class%3D%22%22%3Egoodix-custom%202-005d%3A%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3EINT%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3Enum%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E-22%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%BF%E3%82%A4%E3%83%97%3A0%3C%2FSPAN%3E%3CBR%20%2F%3E%20%5B%20%3CSPAN%20class%3D%22%22%3E2385.431080%3C%2FSPAN%3E%20%5D%3CSPAN%20class%3D%22%22%3Egoodix-custom%202-005d%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20irq%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20-22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AE%E8%A6%81%E6%B1%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AB%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81gpio_to_irq()%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AA%20IRQ%20%E7%95%AA%E5%8F%B7%20(-22%20%3D%20EINVAL)%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3EGPIO%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E647%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E657%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%AD%A3%E3%81%97%E3%81%84%E6%95%B0%E5%AD%97%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EP0_7%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EP2_1%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Ei.MX93%20%E3%81%AE%20PCAL6524%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%91%E3%83%B3%E3%83%80%E3%83%BC%E3%81%AE%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E4%BD%95%E3%81%8B%E7%89%B9%E5%88%A5%E3%81%AA%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%3C%2FSTRONG%3E%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3Epinctrl%3C%2FSTRONG%3E%20%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E4%BD%BF%E7%94%A8%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%91%E3%83%B3%E3%83%80%E3%83%BC%20GPIO%20%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E4%BB%96%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ENXP%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3EPCAL6524%E3%81%8B%E3%82%89%E3%81%AEGPIO%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%93%E3%81%AE%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3Ei.MX93%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%20PCAL6524%20GPIO%20%E3%82%92%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AE%E8%AA%AC%E6%98%8E%E3%82%84%E4%BE%8B%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%9E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Touchscreen%20Driver%20not%20working%20%2C%20GT9271%20chip%20connected%20nxp-imx93frdm%20PCAL6524%20gpio%20expander%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3ENXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81Goodix%20%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%20(GT9xx%20%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA)%20%E3%82%92%3CSTRONG%3Ei.MX93%3C%2FSTRONG%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E4%BD%9C%E6%A5%AD%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AF%3CSTRONG%3EI2C%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x5D%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%3CSTRONG%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20(INT)%3C%2FSTRONG%3E%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A8%3CSTRONG%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20(RST)%3C%2FSTRONG%3E%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%3CSTRONG%3EI2C%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x22%3C%2FSTRONG%3E%E3%81%AB%E3%81%82%E3%82%8B%3CSTRONG%3EI%2FO%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%91%E3%83%B3%E3%83%80%E3%83%BC%20PCAL6524HEAZ%3C%2FSTRONG%3E%20(U725)%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3ECTP_INT%20(%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF)%3C%2FSTRONG%3E%E3%81%AF%20U725%20%E3%81%AE%3CSTRONG%3EP0_7%3C%2FSTRONG%3E%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ECTP_RST%20(%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88)%3C%2FSTRONG%3E%E3%81%AF%20U725%20%E3%81%AE%3CSTRONG%3EP2_1%3C%2FSTRONG%3E%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E3%80%8122%20%E3%83%94%E3%83%B3%20MIPI%20DSI%20FPC%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E3%83%94%E3%83%B318%3A%20DSI_CTP_nINT%20(P0_7)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%94%E3%83%B317%3A%20CTP_RST%20(P2_1)%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%2Fsys%2Fkernel%2Fdebug%2Fgpio%20%E7%B5%8C%E7%94%B1%E3%81%A7%20GPIO%20%E3%83%99%E3%83%BC%E3%82%B9%E3%82%92%E8%AA%BF%E3%81%B9%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3Egpiochip4%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20GPIO%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20640%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20-663%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E8%A6%AA%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20i2c%2F1-0022%E3%80%811%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E-0022%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20CAN%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E5%8F%AF%E8%83%BD%3A%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%3CSTRONG%3E%E3%80%81PCAL6524%20%E3%81%AE%E5%9F%BA%E6%9C%AC%20GPIO%20%E7%95%AA%E5%8F%B7%E3%81%8C%20640%20%E3%81%A7%E3%81%82%E3%82%8B%3C%2FSTRONG%3E%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%E3%83%94%E3%83%B3%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EP0_7%20%3D%20640%20%2B%207%20%3D%20GPIO%20647%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EP2_1%20%3D%20640%20%2B%2016%20(P2%E3%83%99%E3%83%BC%E3%82%B9%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88)%20%2B%201%20%3D%20GPIO%20657%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%A7%81%E3%81%AF%20Goodix%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%80%A4%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%23%20GTP_INT_PORT%20647%3CSPAN%20class%3D%22%22%3E%E3%82%92%E5%AE%9A%E7%BE%A9%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%23%20GTP_RST_PORT%20657%3CSPAN%20class%3D%22%22%3E%E3%82%92%E5%AE%9A%E7%BE%A9%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%20I2C%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81IRQ%20%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%5B%3CSPAN%20class%3D%22%22%3E%202385.431060%3C%2FSPAN%3E%20%5D%3CSPAN%20class%3D%22%22%3E%20goodix-custom%202-005d%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20INT%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20num%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20-22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%82%BF%E3%82%A4%E3%83%97%3A0%3C%2FSPAN%3E%3CBR%20%2F%3E%20%5B%3CSPAN%20class%3D%22%22%3E%202385.431080%3C%2FSPAN%3E%20%5D%3CSPAN%20class%3D%22%22%3E%20goodix-custom%202-005d%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20irq%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E-22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AE%E8%A6%81%E6%B1%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AB%20%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81gpio_to_irq()%20%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AA%20IRQ%20%E7%95%AA%E5%8F%B7%20(-22%20%3D%20EINVAL)%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3EGPIO%20%3CSTRONG%3E647%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3E657%3C%2FSTRONG%3E%E3%81%AF%E3%80%81i.MX93%20%E3%81%AE%20PCAL6524%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%91%E3%83%B3%E3%83%80%E3%83%BC%E3%81%AE%3CSTRONG%3EP0_7%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3EP2_1%3C%2FSTRONG%3E%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E7%95%AA%E5%8F%B7%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E4%BD%BF%E7%94%A8%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%91%E3%83%B3%E3%83%80%E3%83%BC%20GPIO%20%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3CSTRONG%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%3C%2FSTRONG%3E%E3%80%81%20%3CSTRONG%3Epinctrl%3C%2FSTRONG%3E%20%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%A7%E4%BD%95%E3%81%8B%E7%89%B9%E5%AE%9A%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%3CSTRONG%3EPCAL6524%20%E3%81%8B%E3%82%89%E3%81%AE%20GPIO%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20NXP%20%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3Ei.MX93%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%20PCAL6524%20GPIO%20%E3%82%92%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AE%E8%AA%AC%E6%98%8E%E3%82%84%E4%BE%8B%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%9E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Touchscreen%20Driver%20not%20working%20%2C%20GT9271%20chip%20connected%20nxp-imx93frdm%20PCAL6524%20gpio%20expander%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E5%86%8D%E5%BA%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%8C%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%82%82%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
