Toshiba Toggle Flash inquiry
shai_b
Senior Contributor II
Dear Team,
My customer has a small question about using NAND regarding the USB1_SS_SEL pin.
Can you please advise how to connect the USB1_SS_SEL pin when using Nand Flash?
Waiting for your kind feedback, many thanks.
Shai
riteshmpatel
Hi @shai_b,
I hope you are doing well.
Are you looking to use NAND_RE functionality and USB1_SS_SEL functionality as well?
Thanks & Regards,
Ritesh M Patel
shai_b
@riteshmpatel Helllo,
Yes, He wants to use the nRE functionality and USB1_SS_SEL functionality.
Thanks in advance
KR,
Shai
riteshmpatel
Hi @shai_b,
Thank you for the clarification.
USB1_SS_SEL is used as a GPIO. So, if one wants to use NAND_RE functionality, then USB1_SS_SEL shall be mixed with any other available GPIO.
Thanks & Regards,
Ritesh M Patel
shai_b
@riteshmpatel ,
Thanks a lot for your input.
Kind regards
Shai
