Time-multiplexed ITU-R BT.656 format
2,683 次查看
naokinishioka
Dear freescale community
I'd like to use multi-channel NTSC decoder for my i.mx6 solo based system.
Such ICs are TI's TVP5158, intersil's TW2868, maxim's MAX9530 and so on.
But  to achieve 4-channel processing, output format is time-multiplexed ITU-R BT.656 format,
in which, each channel outputs data alternately.
does i.mx6 support time-multiplexed ITU-R BT.656 format ? or standard ITU-R BT.656 format only ?
2,159 次查看
gusarambula
The CSI interface on the i.MX6 solo doesn’t support time-multiplexed ITU-R BT.656, only standard ITU-R BT.656 format.
2,159 次查看
naokinishioka
Hello, gusarambula
Thanks for your answer.
I'll design my board in other ways.
