Thunderbolt compatible with iMX8MPlus
2,364 次查看
GuiDas
I am currently working on the iMX8MPlus and I would like to know if the USB 3.0 connected to an USB C connector  could be compatible with the Thunderbolt protocol ?
Thank you in advance,
Guilhem
2,359 次查看
Bio_TICFSL
Hello GuiDas,
It could be compatible but the transfer going to be as usb 3.0.
2,360 次查看
Bio_TICFSL
Hello GuiDas,
2,349 次查看
GuiDas
Thank you for you answer, I just need a precision,when you say "transfer going to be as usb 3.0", you mean the data rat ?
I have another question following your answer, do I need to implement something special in hardware/software in order to have the thunderbolt ?
Thank you,
Guilhem
2,323 次查看
Bio_TICFSL
Hi, yes i refer to data rate and not change from I.MX side.
regards
