The minimum pulse width specification for WDOG_B
2,579 次查看
george
Senior Contributor II
Hi all,
  • Does WDOGx_B shown in the i.MX8M-Mini data sheet mean the WDOG_B external output signal?
  • Or does it mean the wdog_rst internal signal shown in the reference manual?
We want to know the low width of the WDOG_B external output signal for our product design.
BR,
George
2,519 次查看
Yuri
The external WDOG output signal  (similar as WDOG-1 on the picture)
is not controlled in software.
~Yuri.
4 回复数
2,519 次查看
Yuri
  The CC3 parameters relates to external output signal:
"WDOGx_B output signals (for each one of the Watchdog modules) do not
have dedicated pins, but are muxed out through the IOMUX"
Yuri
2,519 次查看
george
Dear Yuri,
Thank you for your reply.
  • Does CC3 parameter for external output signal you say mean red mark in the figure below
  • Can I make the low pulse width longer by Watchdog register settings?
  • Or is this length uncontollable by the user?
BR,
George
2,520 次查看
Yuri
~Yuri.
2,519 次查看
george
Thanks.
