Dear all,
Our customer runs AndroidKK4.4.3 on i.MX6Q_SABRE_SDB
They use attached HTML.
However, frame skips occur frequently, and the following log is displayed.
"Skipped 37 frames! The application may be doing too much work on its main thread."
This problem does not occur if AndroidKK4.4.2 is used.
Would you teach the probable cause?
Would you teach the point that you should investigate?
yuuki
Original Attachment has been moved to: codepenio.zip
