Tesnorflow C++ Cross Compile Issue
13,514 次查看
weilly_li
Dear All,
      我目前遇到 Tensorflow Lite C++ 無法編譯成功的問題,還請達人幫忙解答!! 感恩
      參考文件 :i.MX Machine Learning User's Guide 文件中章節 3.6 的部分。
      運行平台 :  i.MX8MP , BSP 5.10.35.2.0.0
      運行步驟 :
          >> source /opt/fsl-imx-xwayland/5.10-hardknott/environment-setup-cortexa53-crypto-poky-linux
          >>  cd tensorflow/lite/examples/label_image
          >>  g++  label_image.cc bitmap_helpers.cc ../../tools/evaluation/utils.cc \
                  -I=/usr/include/tensorflow/lite/tools/make/downloads/flatbuffers/include \
                  -I=/usr/include/tensorflow/lite/tools/make/downloads/absl  -O1\
                  -DTFLITE_WITHOUT_XNNPACK -ltensorflow-lite -lstdc++ -lpthread -lm -ldl -lrt
Weilly
13,428 次查看
Zhiming_Liu
我这里编译也会出错,应该是这个版本的问题,你试试L5.4.70_2.3.0
17 回复数
13,510 次查看
Zhiming_Liu
Can you check this point?
After building the Yocto SDK, the TensorFlow Lite artefacts are located as follows:
• TensorFlow Lite shared library (libtensorflow-lite.a) in /usr/lib
• TensorFlow Lite header files in /usr/include
13,498 次查看
weilly_li
Hi, @Zhiming_Liu
       我已確認 SDK 所生成的環境沒有此檔案 libtensorflow-lite.a
           (1) cortexa53-crypto-poky-linu :
           (2) x86_64-pokysdk-linux/
       然後...我將 TOOLCHAIN_TARGET_TASK_append += " tensorflow-lite-staticdev" 加入至 local.conf
       該動作 bitbake -c populate_sdk imx-image-full 就會產生錯誤,無法編譯完成。
Weilly
13,482 次查看
Zhiming_Liu
IMAGE_INSTALL_append += "packagegroup-imx-ml"
TOOLCHAIN_TARGET_TASK_append += " tensorflow-lite-staticdev tensorflow-lite-dev armnn-dev onnxruntime-dev"
试试在local.conf里加上这两行
13,477 次查看
weilly_li
Hi, @Zhiming_Liu
      i have confirmed add it . so I know this toolchian's problem of "tensorflow-lite-staticdev"
      BSP : L5.10.35.2.0.0
      Platform : NXP i.MX8MPlus tesnorflow-lite-satatucdev.png
Weilly
13,471 次查看
Zhiming_Liu
Yocto user guide has error about IMAGE_INSTALL_append ,it should add +
13,465 次查看
weilly_li
Hi, @Zhiming_Liu
      Sorry, Still same problem...
Weilly
13,431 次查看
weilly_li
Hi, @Zhiming_Liu
      還有什麼方式可以幫忙解決嗎? 不然無法生出 SDK ~ 去編譯 Tensorflow ~感恩
Weilly
13,429 次查看
Zhiming_Liu
13,424 次查看
weilly_li
Hi, @Zhiming_Liu
       感謝你幫我測試 !!!! 真的有用心 !!
       那可否請你幫忙向內部的 BSP 工程師 呈報此問題。
       希望在未來的版本能改善 !! 重視此問題~
       畢竟 BSP L5.4.70_2.3.0 所搭配的 Tensorflow 版本太低 ~ 還是希望使用 BSP L5.10.35.2.0.0
       再次,感謝你的熱心有品質的解答 !!
Weilly
13,417 次查看
Zhiming_Liu
试着将local.conf里注释这两个,是可以下载的
#PACKAGE_CLASSES = "package_deb"
#EXTRA_IMAGE_FEATURES += "package-management"
13,406 次查看
weilly_li
Hi, @Zhiming_Liu
      依照你的方法 (註解 local.conf 中的兩行資訊) , 我嘗試了一下!!
      從 log 來看,似乎在 opencv 的編譯上出些問題。
       你也有這個問題嗎 ? 幫忙比對一下 感謝!!!
Weilly
13,395 次查看
Zhiming_Liu
你试着把opencv下载下来的压缩包(download目录)以及它在build目录中解压出来的目录删掉,然后重新编译一下
13,356 次查看
weilly_li
Dear, @Zhiming_Liu
         感謝你的細心幫忙, 我後來照著你的方式還是沒有成功編出有 tensorflow-lite-staticdev 的 SDK.
         在這段時間 , 我也重新編譯 BSP L5.4.47 的版本. 能夠編譯出 SDK , 以及 Tensorflow DEMO.
         剛剛靈光一現想到是不是降版本 (Tensorflow 2.4.1 -> 2.4.0)
         就能解決 BSP L5.10.35 版本無法順利編譯 Tensorflow DEMO 的問題
         測試後,  是可以順利產出執行檔.
         再次感謝你之前的協助!!
Weilly
13,316 次查看
Zhiming_Liu
我测试过即将发布的L5.10.52(Tensorflow 2.5.0),是可以成功编译sdk的。
过两天就会发布,你可以试试。
13,309 次查看
weilly_li
Dear , @Zhiming_Liu
           好的~ 真的非常~感謝你!!
           過陣子我來裝看看!!
Weilly
13,264 次查看
Zhiming_Liu
L5.10.X开始tensorflow不支持静态库编译了,文档都没有即使更新,
tensorflow-lite-staticdev应该移除掉。
13,222 次查看
weilly_li
HI, @Zhiming_Liu
感謝你, 幫忙釐清原因!!!
跟我測試的一樣 ~ 好像是可以不用靜態庫就可以編譯完成了!!
謝謝啦!!
Weilly
