TFTP Boot Process
TFTP Boot Process
3,731 次查看
KrishnaPavan
I need to boot using tftp, but do not know how to do that.
I need to know right from the beginning, I only have tftpd software installed on my Host machine.
Till now, I used SD Card, so then, I already have Bootloader, Kernel Image and rootfs.
But, the requirement is that I should boot using TFTP.
Please kindly help me!            Krishna Pavan
2,937 次查看
KrishnaPavan
Thank You Miroslav Tisma,
It has all the details. Thanks for the link.
Next is to try everything and implement the same from the link.
Regards Krishna Pavan
2,937 次查看
MiroslavIMX53QS
You need to install xinetd, tftp, tftpd, nfs-kernel-server, portmap. But, becasue I can make some mistakes while typing all stuffs that you are needed, you can read the following link. :)
https://linuxlink.timesys.com/docs/gsg/i.MX53START
There you have everything described, step by step.
