Sysfs issue in imx8mm
663件の閲覧回数
Udhay_
i am trying to toggle gpio on i2c expander and it is not affecting anything on my build
if i use /sys/class/ and there is no gpio even if i make gpio by default should gpio496 right?
Why it is not registered gpio496 on under /sys/class/gpio/?
Udhayamoorthi Ramasamy
タグ(1)
644件の閲覧回数
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
What GPIO do you refer to? GPIO on J1004 I2C3_SCL_3V3?
You shouldn't see it because it's reserved for I2C3 which is interfaced with PMIC.
If you adjust device tree for GPIO, it'd be:
MX8MM_IOMUXC_I2C3_SCL_GPIO5_IO18
4 * 32 + 18 = 146
