Switching to DISP1 of parallel RGB display in SDK
1,147件の閲覧回数
adrianthewlis
I want to switch to IPU1_DISP1 pins in the SDK example of the RGB panel. I am enabling the pins with the correct ALT value according to manual, and changing di=0 to di=1, in ipu_display_setup() in ipu_common.c. However I am not seeing any signals coming out of the DISP1 pins.
Is there something else that needs to be changed?
Thanks.
ラベル(2)
タグ(4)
945件の閲覧回数
problem was solved on
iMX6 IPU1 DISP1 and other things
~igor
