Starting GStreamer with systemd.
2,657件の閲覧回数
Patrick-Kim
There is an issue starting GStreamer with systemd.
Entering the following command produces an error message and the video doesn't appear.
Help me find a solution.
root@imx8mpevk:~# systemctl start myservice
root@imx8mpevk:~# systemctl status myservice
* myservice.service - test service
Loaded: loaded (/etc/systemd/system/myservice.service; disabled; preset: disabled)
Active: active (running) since Tue 2024-05-14 02:12:25 UTC; 7s ago
Main PID: 834 (myservice.sh)
Tasks: 2 (limit: 5574)
Memory: 5.1M
CGroup: /system.slice/myservice.service
|-834 /bin/bash /home/root/myservice.sh
`-841 sleep 10
May 14 02:12:25 imx8mpevk systemd[1]: Started test service.
May 14 02:12:25 imx8mpevk myservice.sh[834]: gst start!!
May 14 02:12:25 imx8mpevk myservice.sh[835]: Setting pipeline to PAUSED ...
May 14 02:12:25 imx8mpevk myservice.sh[835]: Failed to set pipeline to PAUSED.
May 14 02:12:25 imx8mpevk myservice.sh[835]: Setting pipeline to NULL ...
May 14 02:12:25 imx8mpevk myservice.sh[835]: Freeing pipeline ...
The same shell script works fine when executed in the console, I can see the video.
root@imx8mpevk:~# ./myservice.sh
gst start!!
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
[ 1033.191967] bypass csc
[ 1033.194381] input fmt YUV4
[ 1033.197096] output fmt YUYV
Redistribute latency...
0:00:00.8 / 99:99:99.
Here is my "myservice.service" and "myservice.sh" file.
myservice.service
[Unit]
Description=GStreamer
After=multi-user.target
[Service]
Type=simple
User=root
ExecStart=/home/root/myservice.sh
RemainAfterExit=yes
GuessMainPID=no
myservice.sh
#!/bin/bash
export XDG_RUNTIME_DIR=/run/user/0/
echo gst start!!
gst-launch-1.0 v4l2src device=/dev/video2 ! waylandsink
Please help!!
2,597件の閲覧回数
Patrick-Kim
Although no one was interested, I found a solution on my own and have summarized it here.
myprogram.service
[Unit]
Description=My Last Service
After=weston.service
[Service]
User=root
Environment="WAYLAND_DISPLAY=/run/wayland-0"
Environment="XDG_RUNTIME_DIR=/run/user/$(id -u root)"
ExecStart=/home/root/run.sh
Restart=on-failure
StandardOutput=journal
StandardError=journal
[Install]
WantedBy=multi-user.target
run.sh
echo Start GST!!
Register service
systemctl daemon-reload
systemctl enable myprogram.service
This way, it works well for me. When I reboot, the camera screen comes up automatically.
2,598件の閲覧回数
Patrick-Kim
myprogram.service
[Unit]
[Service]
User=root
Restart=on-failure
[Install]
run.sh
echo Start GST!!
Register service
%3CLINGO-SUB%20id%3D%22lingo-sub-1864953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Esystemd%20%E3%81%A7%20GStreamer%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1864953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Esystemd%E3%81%A7GStreamer%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CFONT%20size%3D%222%22%3Eroot%40imx8mpevk%3A~%23%20systemctl%20start%20myservice%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3Eroot%40imx8mpevk%3A~%23%20systemctl%20status%20myservice%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E*%20myservice.service%20-%20%E3%83%86%E3%82%B9%E3%83%88%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E6%B8%88%E3%81%BF%3A%20%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E6%B8%88%E3%81%BF%20(%2Fetc%2Fsystemd%2Fsystem%2Fmyservice.service%3B%20%E7%84%A1%E5%8A%B9%3B%20%E3%83%97%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E7%84%A1%E5%8A%B9)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3A%202024%E5%B9%B45%E6%9C%8814%E6%97%A5%E7%81%AB%E6%9B%9C%E6%97%A502%3A12%3A25%20UTC%E4%BB%A5%E9%99%8D%E3%81%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96(%E5%AE%9F%E8%A1%8C%E4%B8%AD)%E3%80%827%E7%A7%92%E5%89%8D%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%E3%83%A1%E3%82%A4%E3%83%B3PID%3A834(myservice.sh)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%E3%82%BF%E3%82%B9%E3%82%AF%3A%202%20(%E5%88%B6%E9%99%90%3A%205574)%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%E3%83%A1%E3%83%A2%E3%83%AA%3A5.1M%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3ECGroup%3A%20%2Fsystem.slice%2Fmyservice.service%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%7C-834%20%2Fbin%2Fbash%20%2Fhome%2Froot%2Fmyservice.sh%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E'-841%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%2010%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A502%3A12%3A25%20imx8mpevk%20systemd%20%5B1%5D%3A%E3%83%86%E3%82%B9%E3%83%88%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A5%2002%3A12%3A25%20imx8mpevk%20myservice.sh%5B834%5D%3AGST%E9%96%8B%E5%A7%8B!!%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A502%3A12%3A25%20imx8mpevk%20myservice.sh%5B835%5D%3A%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A502%3A12%3A25%20imx8mpevk%20myservice.sh%5B835%5D%3A%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A502%3A12%3A25%20imx8mpevk%20myservice.sh%5B835%5D%3A%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92NULL%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E5%E6%9C%8814%E6%97%A5%2002%3A12%3A25%20imx8mpevk%20myservice.sh%5B835%5D%3A%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E8%A7%A3%E6%94%BE...%3C%2FFONT%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E5%90%8C%E3%81%98%E3%82%B7%E3%82%A7%E3%83%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3Eroot%40imx8mpevk%3A~%23%20.%2Fmyservice.sh%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3EGST%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88!!%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E7%A8%BC%E5%83%8D%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81PREROLL%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E4%BA%8B%E5%89%8D%E3%81%AB%E5%B1%95%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%20PLAYING%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A%20GstSystemClock%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%201033.191967%5D%20%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9CSC%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%201033.194381%5D%20%E5%85%A5%E5%8A%9Bfmt%20YUV4%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%5B%201033.197096%5D%20%E5%87%BA%E5%8A%9Bfmt%20YUYV%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AE%E5%86%8D%E9%85%8D%E5%88%86...%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%222%22%3E0%3A00%3A00.8%20%2F%2099%3A99%3A99.%3C%2FFONT%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E3%80%8Cmyservice.service%E3%80%8D%E3%81%A7%E3%81%99%E3%81%A8%20%22myservice.sh%22%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3Emyservice.service%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%5BUnit%5D%0ADescription%3DGStreamer%0AAfter%3Dmulti-user.target%0A%0A%5BService%5D%0AType%3Dsimple%0AUser%3Droot%0AExecStart%3D%2Fhome%2Froot%2Fmyservice.sh%0ARemainAfterExit%3Dyes%0AGuessMainPID%3Dno%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3Emyservice.sh%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23!%2Fbin%2Fbash%0A%0Aexport%20XDG_RUNTIME_DIR%3D%2Frun%2Fuser%2F0%2F%0Aecho%20gst%20start!!%0Agst-launch-1.0%20v4l2src%20device%3D%2Fdev%2Fvideo2%20!%20waylandsink%0A%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!!%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20systemd%20%E3%81%A7%20GStreamer%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877864%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AA%B0%E3%82%82%E8%88%88%E5%91%B3%E3%82%92%E7%A4%BA%E3%81%95%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E8%87%AA%E5%88%86%E3%81%A7%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E3%81%BE%E3%81%A8%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Emyprogram.service%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%E3%80%90%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%80%91%3CBR%20%2F%3Edescription%3D%E7%A7%81%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%3CBR%20%2F%3E%E3%82%A2%E3%83%95%E3%82%BF%E3%83%BC%3Dweston.service%3C%2FP%3E%3CP%3E%E3%80%90%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%80%91%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%3D%E3%83%AB%E3%83%BC%E3%83%88%3CBR%20%2F%3E%E7%92%B0%E5%A2%83%3D%22WAYLAND_DISPLAY%3D%2Frun%2Fwayland-0%22%3CBR%20%2F%3E%E7%92%B0%E5%A2%83%3D%22XDG_RUNTIME_DIR%3D%2Frun%2Fuser%2F%24(id%20-u%20root)%22%3CBR%20%2F%3EExecStart%3D%2Fhome%2Froot%2Frun.sh%3CBR%20%2F%3E%E5%86%8D%E8%B5%B7%E5%8B%95%3D%E5%A4%B1%E6%95%97%E6%99%82%3CBR%20%2F%3EStandardOutput%3D%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%3CBR%20%2F%3EStandardError%3D%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%8A%E3%83%AB%3C%2FP%3E%3CP%3E%5B%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%5D%3CBR%20%2F%3EWantedBy%3D%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC.%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3Erun.sh%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%E3%82%A8%E3%82%B3%E3%83%BC%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88GST!!%3C%2FP%3E%3CP%3EGST%E3%83%AD%E3%83%BC%E3%83%B3%E3%83%81-1.0v4l2src%20device%3D%2Fdev%2Fvideo2%20!%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%A9%E3%83%B3%E3%83%89%E3%82%B7%E3%83%B3%E3%82%AF%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3Esystemctl%20%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3-%E3%83%AA%E3%83%AD%E3%83%BC%E3%83%89%3CBR%20%2F%3Esystemctl%20enable%20myprogram.service%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E7%94%BB%E9%9D%A2%E3%81%8C%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E5%87%BA%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
