Software ASRC library available from NXP?
sgordon777
Hello, I'm developing audio applications for the MIMX8 and MIMX95 families and require an ASRC.
I don't believe that hardware ASRC is availble for MIMX8 mini or IMX95 series so I'm inquiring about software library to do this job,
Appreciate any info, Thanks.
sgordon777
Unfortunately, I cannot see dates on these messages(they only say "two weeks ago"). The last reply I got from you was this:
>> we have patch for imx8mn/imx8mp SARC support steps, let me check if I can share with you directly or not
Did you share this thorough some other means?
joanxie
current bsp already includes ASRC demo and code, after building, the path is
 tmp/work/armv8a-poky-linux/imx-dspc-asrc/1.0.1-r0/imx-dspc-asrc-1.0.1:
- test/src/test.c: An ASRC demo code
- release/exe/asrc-test: ASRC execution binary
- release/lib/lib_dspc_asrc*: ASRC lib
- Release_note.txt: The guide to run asrc-test
joanxie
this SW should be developed by the expert team, if you need it, you can contact them, but as I known, we only develop one for customer on imx8mp, maybe you can contact them to get further detailed information
https://www.nxp.com/support/support/nxp-engineering-services:SW-SUPPORT
joanxie
sgordon777
Any word on this Joanxi?
joanxie
I already replied to you on 5/21, pls check it
