Software ASRC library available from NXP?
1,810 次查看
sgordon777
Hello, I'm developing audio applications for the MIMX8 and MIMX95 families and require an ASRC.
I don't believe that hardware ASRC is availble for MIMX8 mini or IMX95 series so I'm inquiring about software library to do this job,
Appreciate any info, Thanks.
6 回复数
1,627 次查看
sgordon777
Unfortunately, I cannot see dates on these messages(they only say "two weeks ago"). The last reply I got from you was this:
>> we have patch for imx8mn/imx8mp SARC support steps, let me check if I can share with you directly or not
Did you share this thorough some other means?
1,594 次查看
joanxie
current bsp already includes ASRC demo and code, after building, the path is
 tmp/work/armv8a-poky-linux/imx-dspc-asrc/1.0.1-r0/imx-dspc-asrc-1.0.1:
- test/src/test.c: An ASRC demo code
- release/exe/asrc-test: ASRC execution binary
- release/lib/lib_dspc_asrc*: ASRC lib
- Release_note.txt: The guide to run asrc-test
1,783 次查看
joanxie
this SW should be developed by the expert team, if you need it, you can contact them, but as I known, we only develop one for customer on imx8mp, maybe you can contact them to get further detailed information
https://www.nxp.com/support/support/nxp-engineering-services:SW-SUPPORT
1,788 次查看
joanxie
1,712 次查看
sgordon777
Any word on this Joanxi?
1,643 次查看
joanxie
I already replied to you on 5/21, pls check it
