Slow menus in Qt GPU Demos
varsmolta
when I build yocto fsl-image-gui (danny branch), I noticed that there are Qt demos on the desktop. I ran some of them and noticed lag when navigating thru the menu. Most of the GPU demos ran fine, but what is causing the slow menu? Is it not using acceleration? Are these demos done in Qt5?
OtavioSalvador
Senior Contributor II
The demos are from Qt4.
Without a better understanding which demos you're testing it is hard to have a guess. May you provide more information?
