Sgtl5000 Audio Codec Config
1,844件の閲覧回数
ahmedhafez
Hello
I have some questions about how to Successfully configure Sgtl5000 audio codec .
if i can use I2C communication without connecting VDDD if yes then i will  connect VDDD to Ground or not?
If i can connect VDDA , VDDIO , VDDD to the same voltage source like 1.8 volt ?
could you guide me . how to use Crystal to provide MCLK   ?
i try a lot to configure the Sgtl5000 audio codec through reading the chip ID but i can't could you guide me step by step from scratch ?
Thanks and best regards
タグ(1)
1,659件の閲覧回数
igorpadykov
Hi ahmed
please look at sgtl5000 documentation and programming guides on
Ultra-Low-Power Audio Codec|NXP
