Sgtl5000 Audio Codec Config
756 次查看
ahmedhafez
Hello
I have some questions about how to Successfully configure Sgtl5000 audio codec .
if i can use I2C communication without connecting VDDD if yes then i will  connect VDDD to Ground or not?
If i can connect VDDA , VDDIO , VDDD to the same voltage source like 1.8 volt ?
could you guide me . how to use Crystal to provide MCLK   ?
i try a lot to configure the Sgtl5000 audio codec through reading the chip ID but i can't could you guide me step by step from scratch ?
Thanks and best regards
标记 (1)
571 次查看
Hi ahmed
please look at sgtl5000 documentation and programming guides on
Ultra-Low-Power Audio Codec|NXP
