Setting AP mode IN IMX93 FRDM BOARD
866 次查看
Et_MM
I am working with imx93 frdm board. I have to configure the board to AP mode for that i thad followed the procedures mentioned in this "Lab 1. Wi-Fi-Basic-Hands-on.pdf" document in that section 6.5 only i have done.
At last i was able to see the name i set for this board in my phone when i try to connect by giving password it is showing unable to connect. Do i need to do any additional steps other than mentioned in that section, please suggest.
Please go through the image shared , the output i am getting and what is mentioned in the document, you can see the difference. how to clear this issue?
标记 (1)
815 次查看
Zhiming_Liu
Hi @Et_MM
Please run basic tests from beginning referring the guide.
Zhiming
