Set VBR with bitrate limit IMX8MM
1,005 次查看
DR_Akzhol
Hello there, could you find a solution for that? We have tested VBR with highprofile mode. At DAY we have normal Bitrate 100kb-3Mb, night time camera gives more noise, so the bitrate goes to 15-20Mb (too big files at night). How can we limit the upper bitrate for VBR mode, or what kind of parameters can be adjusted to get lower bitrate at night
11 回复数
848 次查看
DR_Akzhol
Is there any solution for this?
975 次查看
Manuel_Salas
Hello @DR_Akzhol
I hope you are doing very well.
Could you please share more details about your application?
What BSP you are using? Are you using GStreamer, V4L2?
Salas.
945 次查看
DR_Akzhol
Hello Manuel,
Ubuntu, Kernel 5.4.70
Modified VPU driver to enable highprofile
Using Gstreamer included into Ubuntu and V4L2, VPUENC plugin.
VBR: Set Quant = 35, bitrate = 0(default)
Our goal is to get VBR in range up to 3Mb bitrate (not above this)
943 次查看
Manuel_Salas
Hello @DR_Akzhol
you can try setting an explicit maximum bitrate. Try the following:
$ gst-launch-1.0 v4l2src ! videoconvert ! vpuenc_h264 bitrate=0 quant=35 max-bitrate=3000000 ! mp4mux ! filesink location=output.mp4
Salas.
标记 (1)
928 次查看
DR_Akzhol
We do not see this option for vpuenc. See message:
"WARNING: erroneous pipeline: no property "max-bitrate" in element "vpuenc_h264-0""
833 次查看
Manuel_Salas
Please run:
$ gst-inspect-1.0 vpuenc_h264
Then look for bitrate options to see if vpuenc_264 supports bitrate options.
Salas.
807 次查看
DR_Akzhol
Checked,
There is option -bitrate (CBR)
There is no option -max-bitrate
703 次查看
DR_Akzhol
Plugin Details:
Name vpu
Description VPU video codec
Filename /usr/lib/gstreamer-1.0/libgstvpu.so
Version 4.6.3
License LGPL
Source module imx-gst1.0-plugin
Binary package Freescle Gstreamer Multimedia Plugins
Origin URL http://www.freescale.com
Element Properties:
bitrate : set bit rate in kbps (0 for automatic)
flags: readable, writable
Unsigned Integer. Range: 0 - 2147483647 Default: 0
gop-size : How many frames a group-of-picture shall contain
Unsigned Integer. Range: 0 - 32767 Default: 30
min-force-key-unit-interval: Minimum interval between force-keyunit requests in nanoseconds
Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 0
name : The name of the object
flags: readable, writable, 0x2000
String. Default: "vpuenc_h264-0"
parent : The parent of the object
Object of type "GstObject"
qos : Handle Quality-of-Service events from downstream
Boolean. Default: false
quant : set quant value: H.264(0-51) (-1 for automatic)
Integer. Range: -1 - 51 Default: -1
703 次查看
DR_Akzhol
Have check already, there is option -bitrate, no option -max-bitrate
Factory Details:
Rank primary + 1 (257)
Long-name IMX VPU-based AVC/H264 video encoder
Klass Codec/Encoder/Video
Description Encode raw data to compressed video
Author Multimedia Team <shmmmw@freescale.com>
Plugin Details:
Name vpu
Version 4.6.3
License LGPL
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstVideoEncoder
+----vpuenc_h264
Implemented Interfaces:
GstPreset
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-h264
stream-format: { (string)avc, (string)byte-stream }
alignment: { (string)au, (string)nal }
SINK template: 'sink'
Capabilities:
video/x-raw
format: { (string)NV12, (string)I420, (string)YUY2, (string)UYVY, (string)RGBA, (string)RGBx, (string)RGB16, (string)RGB15, (string)BGRA, (string)BGRx, (string)BGR16 }
width: [ 64, 1920 ]
height: [ 64, 1088 ]
framerate: [ 0/1, 2147483647/1 ]
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SINK: 'sink'
Pad Template: 'sink'
SRC: 'src'
Pad Template: 'src'
Element Properties:
标记 (3)
703 次查看
DR_Akzhol
Factory Details:
Plugin Details:
Name vpu
Version 4.6.3
License LGPL
GObject
+----GstObject
+----GstElement
+----vpuenc_h264
GstPreset
Pad Templates:
SRC template: 'src'
Capabilities:
video/x-h264
Capabilities:
video/x-raw
width: [ 64, 1920 ]
Pads:
SINK: 'sink'
SRC: 'src'
Pad Template: 'src'
Element Properties:
There is option -bitrate, no option max-bitrate
703 次查看
DR_Akzhol
Factory Details:
Plugin Details:
Name vpu
Version 4.6.3
License LGPL
GObject
+----GstObject
+----GstElement
+----vpuenc_h264
GstPreset
Pad Templates:
SRC template: 'src'
Capabilities:
video/x-h264
Capabilities:
video/x-raw
width: [ 64, 1920 ]
Pads:
SINK: 'sink'
SRC: 'src'
Pad Template: 'src'
Element Properties:
There is option -bitrate, there is no option -max-bitrate
