Segmentation fault during g2d_blit
1,483 次查看
marko1921
/usr/lib/libGAL.so(gco2D_SetYUVColorMode+0x70)[0xffff7b9e38f0]
/usr/lib/libg2d.so.1.5(g2d_blitEx+0xdcc)[0xffff7ed73904]
/usr/lib/libg2d.so.1.5(g2d_blit+0x90)[0xffff7ed742b8]
Sometimes g2d_blit function throws sementation fauld with above stack trace
Could you please help to find root cause. Usually my code works fine but sometimes it throws seg fault.
1,446 次查看
marko1921
g2d frame buffer is full.
Thanks. You mentioned that g2d frame buffer is full. In what situations this g2d frame buffer gets full?
1,465 次查看
Bio_TICFSL
The software has attempted to access a restricted area of memory, check your dtb appears the g2d frame buffer is full.
