Segmentation fault during g2d_blit
1,455件の閲覧回数
marko1921
/usr/lib/libGAL.so(gco2D_SetYUVColorMode+0x70)[0xffff7b9e38f0]
/usr/lib/libg2d.so.1.5(g2d_blitEx+0xdcc)[0xffff7ed73904]
/usr/lib/libg2d.so.1.5(g2d_blit+0x90)[0xffff7ed742b8]
Sometimes g2d_blit function throws sementation fauld with above stack trace
Could you please help to find root cause. Usually my code works fine but sometimes it throws seg fault.
2 返答(返信)
1,418件の閲覧回数
marko1921
g2d frame buffer is full.
Thanks. You mentioned that g2d frame buffer is full. In what situations this g2d frame buffer gets full?
1,437件の閲覧回数
Bio_TICFSL
The software has attempted to access a restricted area of memory, check your dtb appears the g2d frame buffer is full.
