Segmenation Fault from ONNX runtime perf test
1,842 次查看
JK-IMX
Hi NXP
There's a request that Customer wants to get clarified.
They found an issue when running onnxruntime_perf_test after tried to build model_quant.onnx (Quantized ONNX model) from model.onnx.
The segmentation fault is reproducible with lots of "vsai_npu_executiion_provider.cc.168 GetUnsupportedNodeIndicies] unsuppported node" during the test.
The followings are the log message captured during test.
Please check the issue to avoid this error from ONNX Runtime Test.
<Log>
root@imx8mp-lpddr4-evk:/usr/bin/onnxruntime-1.8.2# /usr/bin/onnxruntime-1.8.2/onnxruntime_perf_test /usr/bin/onnxruntime-1.8.2/squeezenet/model_quant.onnx -r 1
-e vsi_npu
2021-03-24 10:39:38.492309250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:38.492528250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.492568875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:38.492595625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:38.492622625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.492653250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:38.492709500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:38.492736000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.492767125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.492813500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:38.492844375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.492874500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:38.492899375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:38.492924125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.492953500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:38.492995625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:38.493021250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.493052750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.493085750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:38.493116125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.493146250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:38.493171000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:38.493195500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.493224875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:38.493266000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:38.493293625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.493325375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.493361375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.493392000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:38.493417000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:38.842058000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.842122375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:38.842190875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:38.842231000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.842278125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.842339875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:38.842385625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.842430875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:38.842467625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:38.842503875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.842547000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:38.842608750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:38.842646750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.842693250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.842740625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:38.842785625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.842830500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:38.842867000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:38.842902875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.842946750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:38.843009125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:38.843046750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.843092625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.843146750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:38.843192250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:38.843228875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:38.843265875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:38.843308750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:39.191054500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:39.191101875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.191152375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.191227375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:39.191274375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.191319750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:39.191357000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:39.191394750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.191438125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:39.191498375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:39.191536000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.191580625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.191627250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:39.191673875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.191719000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:39.191755625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:39.191791875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.191834750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:39.191895500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:39.191933500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.191980250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.192035750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.192080500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:39.192117000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:39.192155250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.192198375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:39.192302500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:39.540312125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.540375000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.540437125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:39.540484875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.540530375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:39.540567375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:39.540603875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.540647000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:39.540711125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:39.540749500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.540796625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.540844625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:39.540889000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.540933625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:39.540970625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:39.541006625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.541051000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:39.541112125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:39.541151625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.541196625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.541250500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.541295375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:39.541332250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:39.541368625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.541411750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:39.541470250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:39.541507750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.541555625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.890240000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:39.890294375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.890342000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:39.890378750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:39.890415625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.890458875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:39.890521125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:39.890558875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.890603875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.890651625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:39.890697250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.890742000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:39.890778750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:39.890815000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.890858125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:39.890932000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:39.890977125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.891026375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.891082000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.891127250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:39.891164250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:39.891201375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.891244750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:39.891303500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:39.891342500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:39.891387000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:39.891444250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:39.891489750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.239186000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:40.239231750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:40.239269000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.239313000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:40.239376750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:40.239415250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.239461625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.239509875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:40.239555250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.239600375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:40.239637125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:40.239673250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.239717250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:40.239778875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:40.239816375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.239861250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.239914625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.239959375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:40.239996250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:40.240032125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.240075000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:40.240133750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:40.240171625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.240217500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.240298000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:40.240346250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.240391875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:40.588190750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:40.588253125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.588302000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:40.588367625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:40.588406000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.588452375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.588500750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:40.588548250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.588593500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:40.588630625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:40.588667000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.588710250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:40.588772500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:40.588810375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.588855250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.588910000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.588954875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:40.588991750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:40.589028750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.589071625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:40.589131000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:40.589168500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.589214875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.589271375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:40.589318250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.589362250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:40.589399875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:40.589436125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.937785500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:40.937858125 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:40.937896875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.937943875 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.937992375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:40.938037750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.938083500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:40.938120500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:40.938157250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.938200250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:40.938262625 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:40.938300250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.938347750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.938401375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.938446500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:40.938483250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:40.938519750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.938563000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:40.938623250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:40.938661750 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.938707375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.938764250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:DynamicQuantizeLinear
2021-03-24 10:39:40.938809375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
2021-03-24 10:39:40.938855375 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Div
2021-03-24 10:39:40.938892000 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Floor
2021-03-24 10:39:40.938928250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:40.938971250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Reshape
2021-03-24 10:39:40.939033250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Add
2021-03-24 10:39:41.287395250 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Cast
2021-03-24 10:39:41.287464500 [W:onnxruntime:Default, vsi_npu_execution_provider.cc:168 GetUnsupportedNodeIndices] unsupported node:Mul
[  870.204581] audit: type=1701 audit(1616582381.544:8): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1210 comm="onnxruntime_per" exe="/usr/bin/onnxruntime-1.8.2/onnxruntime_perf_test" sig=11 res=1
Segmentation fault
0 回复数
