Hi Igor,
I've seen the posts related to the "Error - CSF lies outside the image bounds" issue, but i'm still stacked. I checked all the step of HAB tutorial, and all seems correctly done. Could the problem be indexing related even if the unlocked system correctly boot?
You can find all the file .csf file used below.
------ var-default.csf ------
[Header]
Version = 4.1
Hash Algorithm = sha256
Engine = ANY
Engine Configuration = 0
Certificate Format = X509
Signature Format = CMS
[Install SRK]
File = "../../crts/SRK_1_2_3_4_table.bin"
Source index = 0 # Index of the key location in the SRK table to be installed
[Install CSFK]
# Key used to authenticate the CSF data
File = "../../crts/CSF1_1_sha256_4096_65537_v3_usr_crt.pem"
[Authenticate CSF]
[Install Key]
# Key slot index used to authenticate the key to be installed
Verification index = 0
# Target key slot in HAB key store where key will be installed
Target index = 2
# Key to install
File = "../../crts/IMG1_1_sha256_4096_65537_v3_usr_crt.pem"
[Authenticate Data]
# Key slot index used to authenticate the image data
Verification index = 2
# Address Offset Length Data File Path
------ u-boot-ivt.img.csf ------
[Header]
Version = 4.1
Engine = SW
[Install SRK]
[Install CSFK]
[Authenticate CSF]
[Install Key]
Target index = 2
# Key to install
[Authenticate Data]
Blocks = 0x85ffffc0 0x0000 0x00057020 "u-boot-ivt.img"
------ SPL.csf ------
[Header]
Version = 4.1
Engine = SW
[Install SRK]
[Install CSFK]
[Authenticate CSF]
[Install Key]
Target index = 2
# Key to install
[Authenticate Data]
Blocks = 0x00908400 0x00000000 0x0000ac00 "SPL"
[Unlock]
Engine = CAAM
Features = RNG
------ zImage-ivt.csf ------
[Header]
Version = 4.1
Engine = SW
[Install SRK]
[Install CSFK]
[Authenticate CSF]
[Install Key]
Target index = 2
# Key to install
[Authenticate Data]
Blocks = 0x82000000 0x0000 0x6a3020 "zImage-ivt"
Can you give me some further hint?
Thank you for the support,
Best
