Searching for ISP documentation
1,458 次查看
Ladislav
the following page lists the i.MX 9 Applications Processors: i.MX 9 Application Processors . I'm specifically interested in the i.MX 95 since it contains the Image Signal Processing (ISP) unit.
Can I find some documentation for this specific ISP unit?
I found a very brief application note for the i.MX 8 application processor, which may or may not be relevant in my case: Software ISP Application Note
In general, I am interested in learning more about utilizing the i.MX 9 application processors for image processing. Any assistance or guidance in this regard would be greatly appreciated.
Ladislav
标记 (3)
1,441 次查看
joanxie
to be honest, imx95 is still under design, we don't have any information for ISP to share public customer, and the softISP you mentioned which uses GPU, and imx95 doesn't use the same GPU as imx8 series, for imx8 series, GPU is from VSI and for imx95, GPU is from ARM
