What type of touch panel are you using?
Did you check if you have a corresponding .idc file under /system/usr/idc directory?
I ran into similar problem when I setup my touch panel. Once I drop in the idc file. The touch panel just works.
I also would like to ask a favor from you.
I am running KK442 on a custom board based on SabreSD. By set ro.sf.hwrotation to 270, my LCD screen rotates as expected. However I always see error messages in logcat :
( 2302): g2d_blit: Invalid src rect, left 0, top 0, right 600, bottom 800, width 800, height 600, stride 800!
Could you please take a look if you have the same issue?
I couldn't figure out what has caused it. Any help will be appreciated.
Lei
