SSI1 master mode
SSI1 master mode
1,419 次查看
johnturnur
I want to set up SSI1 in master mode to clock my slave audio amplifier. SSI clocking = 64* fs.
What code change required to do this?
How to change SSI clocking and select SSI clock source?
John
1,229 次查看
YixingKong
Senior Contributor IV
John, which platform are you using? What is the OS?
Regars,
Yixing
