SPI Nor Flash M25P16
syedr1
Hi Team,
Currently I am working on i.MX Processor for SPI NOR Flash M25P16 from Micron on Kernel Version 6.1.38..
I am getting below error
spi-nor spi0.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00 00.
Please let me know How I can proceed
Labels (3)
syedr1
Hi Jimmy,
Thank you,Now Nor flash is detecting .Now I have only mtd0.
How do I create different blocks for Nor flash like mtd0, mtd1, mtd2, mtd3 etc
Please suggest
jimmychan
If you have more NOR flash on your board, you could create different MTD for the flash.
syedr1
Hi Jimmy,
Thanks for the reply.
Actually I have 32 blocks in Nor flash.Please provide below information.
1.How to write and read data to/from each block.
2.Is it necessary to erase the data before writing to each block?
3.Is there any command to get RDID of nor flash using command line
jimmychan
