I want to allocate memory for a cam driver by function dma_alloc_contiguous() which is using CMA internally.
I declare the cma region for my cam driver in device tree in kernel's cmdline. (cma=a=64M cma_map=mycam=a). The drivers name is "mycam". But this is field isn't set in init_name in device struct neither.
The problem is dma_alloc_contiguous needs struct device's field cma which is NULL when the probe function of mycam is called. Do I have to set this field on my own?
Im using i.MX8mp Kernel 5.10.35
