SDIO throughput
SDIO throughput
rexprith
Fresh Out Contributor
What is the maximum SDIO throughput in i.MX based Nitrogen6X boards?
Appreciate help!
EricNelson
Senior Contributor II
The microSD card slots don't support voltage switching, so the max clock rate is 50MHz (x4 bits), for a nominal bandwidth of 200Mb/s.
We have hardware in place on Nitrogen6_Max for voltage switching, but have not yet implemented the negotiation and voltage switch.
