SAI2 permanent clock
lfulek
We are using SAI2 interface of IMX8MP to connect to Audio transceiver. Audio transceiver has requirement of permament Frame Sync clock (TXFS) on I2S interface. If we use a dummy codec for the sound card, we can see correctly the clock signals coming out this interface whenever we play a sound from user space. If we don't play any sound, the clocks are suspended.
We tried to comment out clk_disable_unprepare in fsl_sai.c but it did not helped. We need to have this clock always present (since boot-up). Does anyone know how to get this feature?
