Running toaster problem
2,096件の閲覧回数
hkhunkim
when I try to run bitbake with toaster, I always get below error
command: unset BBPATH; bash -c "source /home/hk/yocto/poky/oe-init-build-env /home/hk/yocto/poky/build-toaster-4; BITBAKE_UI="knotty" /home/hk/yocto/poky/bitbake/bin/bitbake --read /home/hk/yocto/poky/build-toaster-4/conf/toaster.conf --read /home/hk/yocto/poky/build-toaster-4/conf/toaster-bblayers.conf --server-only -B 0.0.0.0:0"  b'ERROR: Unable to start bitbake server\n'
command bitabke from terminal seems work nicely, but I don't know why it doesn't work with toaster.
ラベル(2)
タグ(2)
1,584件の閲覧回数
gusarambula
Hello Hun Kim,
Toaster is not supported by the BSP as of today. You may be able to get it running on the Community BSP as it’s part of the Yocto project but in my experience the way the layers are handled makes it not to work.
