Rpmsg enabling patch file
3,546 次查看
arunsathian
Is the attached patch file suitable for L5.10 also?
or else what are the changes need to be done in this patch file.
3,447 次查看
Zhiming_Liu
Hi @arunsathian
You can refer  AN5317 Loading Code on Cortex-M from U-Boot/Linux for the i.MX Asymmetric Multi-Processing Application Processors
https://www.nxp.com/docs/en/application-note/AN5317.pdf
Best Regards
Zhiming
5 回复数
3,536 次查看
Zhiming_Liu
Hi @arunsathian
You can't use it directly, there are lots of changes in framework and dts.
3,529 次查看
arunsathian
Hi @Zhiming_Liu
what are the changes need to be done in this patch file?Can you please explain in a brief?
3,522 次查看
Zhiming_Liu
The device tree changes a lot(arch/arm64/boot/dts/freescale/imx8qxp-mek-rpmsg.dts), and L5.10 don't use rpmsg driver anymore, it uses remoteproc framework.
3,473 次查看
arunsathian
Hi @Zhiming_Liu
Are you saying that for L5.10 version we strictly need to use remoteproc instead of rpmsg?
If do so can you please share any documents related with it.
3,448 次查看
Zhiming_Liu
Hi @arunsathian
Best Regards
Zhiming
