Removal of PKCS#11 functionality in CST tool
1,851 次查看
pfaust60
I just downloaded the latest CST tool 3.3.1 and found this in the documentation.
The /back_end-hsm directory contains the sources and headers necessary for replacing the open source cryptographic libraries with an implementation that can interact directly with a Hardware Security Module (HSM) by using the PKCS#11 interface definition. More detailed information can be found in the README file located in the directory.
Note: This add-on is deprecated and will be removed in the next CST release.
What will this be replaced with?  Having private keys on the build machine is not a very safe practice.
1,838 次查看
Zhiming_Liu
Hi @pfaust60
We will release a safer way to enable HSM in next version.
Zhiming
1,669 次查看
Hendrik_M
Is there an update on the status of the new HSM implementation? This is also a pressing matter on my team.
1,828 次查看
pfaust60
Thanks for the update.  When should we expect a new release and be able to evaluate the new mechanism for integrating with an HSM.
I assume the new solution will still use the industry standard pkcs#11 interface?
Paul Faust
