Regarding 8M Plus Real time Accuracy
1,109件の閲覧回数
hankwang
Contributor V
Hi,  We would like to lean more about 8M Plus capabilities regarding its real-time applications. Are there any test reports or related materials available concerning TSN or real-time performance, or jitter?
1,047件の閲覧回数
yipingwang
Area Available material What it contains
Real-time CPU/RTOS latency Harpoon User’s Guide Measured real-time latencies on i.MX 8M Plus / Zephyr , including IRQ latency and task latency in ns. Example results: no-load IRQ latency min/avg/max/stddev = 625 / 796 / 11,125 / 1,798 ns ; task latency = 2,583 / 2,671 / 13,041 / 6,045 ns . Under Linux CPU + memory load, IRQ latency = 625 / 798 / 4,250 / 4,674 ns , and task latency = 2,583 / 2,670 / 14,333 / 10,407 ns .
Real-time benchmark method Harpoon User’s Guide — rt latency application Defines the benchmark as the time delta between hardware IRQ events and software actions, measured with a hardware timer and sub-microsecond precision.
TSN capability i.MX 8M Plus product / reference material i.MX 8M Plus includes dual Gb Ethernet, with one Ethernet supporting TSN, and uses the integrated 800 MHz Arm Cortex-M7 for industrial real-time control.
TSN hardware standards i.MX 8M Plus Reference Manual TSN support includes IEEE 802.1Qbv Time-Aware Shaper , 802.1Qav Credit-Based Shaper , IEEE 1588v2 PTP , and the Ethernet block implements 802.1Qbv-2015 , 802.3br , and 802.1Qbu frame preemption-related TSN functions.
TSN test / validation environment
Real-Time Edge User Guide
Describes a TSN test environment for evaluating i.MX 8M Plus TSN capabilities, including traffic generation/analysis and monitoring of latency, jitter, and synchronization accuracy.
TSN jitter / latency example Real-Time Edge User Guide — TSN endpoint sample app Provides TSN endpoint statistics including traffic latency min/mean/max and notes latency around 503 µs with latency jitter around 300 ns in the shown example.
TSN application demo AN13588 Demonstrates a GenAVB/TSN real-time control application. It describes a 2 ms cycle , a 400 µs reserved/guaranteed control-traffic window , and a statistics thread for scheduling, processing timing, traffic correctness, and latency.
TSN 802.1Qbv demo AN13995 Demonstrates TSN 802.1Qbv using i.MX 8M Plus and explains how time-aware shaping uses fixed repeating cycles to provide deterministic latency; it also includes Linux tc / taprio configuration examples.
7 返答(返信)
1,096件の閲覧回数
hankwang
Contributor V
Our distributor informed us that there is currently no official performance report available for the NXP i.MX95 EVK regarding real-time performance or jitter.
However, they also provided documentation describing the testing methodology (e.g., cyclictest) for evaluating real-time latency.
This leads to some confusion on our side. Since a standardized testing methodology exists, we assume that such tests must have been performed internally—at least on the reference EVK platform.
Therefore, we would like to clarify:
  • Has NXP conducted any internal measurements of real-time performance (e.g., latency, jitter) on the i.MX95 EVK?
  • If so, are there any reference or baseline results that could be shared?
We understand that real-time performance may vary depending on system configuration and workload. However, even a baseline result under controlled conditions (e.g., default BSP, minimal load) would be very helpful for initial evaluation.
Thank you for your support.
1,082件の閲覧回数
yipingwang
We understand that no public "real-time performance report" has been officially released for i.MX95 EVK. However, NXP does internally perform real-time benchmarking on i.MX95 platforms. Internal benchmark documents indicate that cyclictest and EtherCAT performance evaluations have been executed on i.MX95 LPDDR5 EVKs running Real-Time Edge software with PREEMPT_RT Linux. Reported examples include a maximum cyclictest latency of approximately 38 µs during a 6-hour stress-ng test and EtherCAT filtered maximum jitter of approximately 12 µs under the documented test conditions. Because real-time performance depends strongly on BSP version, kernel configuration, CPU isolation, workload, and network traffic, these values should be considered reference measurements rather than guaranteed application-level limits.
as supported benchmarking platforms and provide detailed cyclictest, stress, and rt_latency procedures.
1,057件の閲覧回数
hankwang
Contributor V
@yipingwang
Thank you for providing the information. Could you also please provide us with information about the iMX8M Plus EVK?
Thanks.
1,048件の閲覧回数
yipingwang
1,033件の閲覧回数
hankwang
Contributor V
@yipingwangThank you very much for the information you provided.
1,097件の閲覧回数
yipingwang
  1. REALTIMEEDGEUG (Real-Time Edge Software User Guide) (https://www.nxp.com/docs/en/user-guide/REALTIMEEDGEUG.pdf)
. Real-Time Edge Software (most relevant)
NXP's Real-Time Edge Software officially supports the i.MX8M Plus EVK and includes:
  • PREEMPT_RT Linux
  • TSN stack
  • IEEE 802.1AS (gPTP) synchronization
  • TSN traffic shaping and scheduling
  • EtherCAT, OPC-UA, CAN-related industrial protocols
  • Heterogeneous real-time operation using Cortex-A53 + Cortex-M7
The internal document REALTIMEEDGEUG states that Real-Time Edge Software provides:
  • Real-time networking (TSN)
  • Real-time Linux (PREEMPT_RT)
  • Pure RTOS/Bare-metal options
  • Jailhouse partitioning
  • Industrial protocol support
Support for i.MX 8M Plus LPDDR4 EVK
  1. NXP Application Note AN13995 – TSN 802.1Qbv Demonstration using i.MX 8M Plus
  2. The Real-Time Edge Six Pack materials describing PREEMPT_RT + TSN support
382件の閲覧回数
zhijie
How to download:
1 Real-Time Edge Six Pack materials
2 Real-Time Edge User Guide — TSN endpoint sample app
3 Real-Time Edge User Guide
4 Harpoon User’s Guide — rt latency application
5 Harpoon User’s Guide
6 AN13588
%3CLINGO-SUB%20id%3D%22lingo-sub-2394723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E8M%E4%BB%A5%E4%B8%8A%E3%81%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E7%B2%BE%E5%BA%A6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%828M%20Plus%E3%81%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E8%A9%B3%E3%81%97%E3%81%8F%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82TSN%E3%82%84%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%80%81%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%86%E3%82%B9%E3%83%88%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%82%84%E9%96%A2%E9%80%A3%E8%B3%87%E6%96%99%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2394723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22overflow-x-auto%20rounded-lg%20border%20border-border%20bg-background%22%3E%0A%3CTABLE%3E%0A%3CTHEAD%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTH%20class%3D%22px-2%20py-1.5%20text-left%20font-semibold%22%3E%E3%82%A8%E3%83%AA%E3%82%A2%3C%2FTH%3E%0A%3CTH%20class%3D%22px-2%20py-1.5%20text-left%20font-semibold%22%3E%E5%85%A5%E6%89%8B%E5%8F%AF%E8%83%BD%E3%81%AA%E8%B3%87%E6%96%99%3C%2FTH%3E%0A%3CTH%20class%3D%22px-2%20py-1.5%20text-left%20font-semibold%22%3E%E5%86%85%E5%AE%B9%E7%89%A9%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0CPU%2FRTOS%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3E%E3%83%8F%E3%83%BC%E3%83%97%E3%83%BC%E3%83%B3%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3Ei.MX%208M%20Plus%20%2F%20Zephyr%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%A7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%80%81IRQ%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%84%E3%82%BF%E3%82%B9%E3%82%AF%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7(ns%E5%8D%98%E4%BD%8D)%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AE%E7%B5%90%E6%9E%9C%3Ano-load%20IRQ%20%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%20min%2Favg%2Fmax%2Fstddev%20%3D%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%20625%20%2F%20796%20%2F%2011%2C125%20%2F%201%2C798%20ns%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%20%3D%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%202%2C583%20%2F%202%2C671%20%2F%2013%2C041%20%2F%206%2C045%20ns%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%80%82Linux%20CPU%20%2B%20%E3%83%A1%E3%83%A2%E3%83%AA%E8%B2%A0%E8%8D%B7%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81IRQ%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%3D%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%20625%20%2F%20798%20%2F%204%2C250%20%2F%204%2C674%20ns%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%80%81%E3%82%BF%E3%82%B9%E3%82%AF%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%3D%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%202%2C583%20%2F%202%2C670%20%2F%2014%2C333%20%2F%2010%2C407%20ns%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E6%96%B9%E6%B3%95%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3EHarpoon%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%20%E2%80%94%20RT%20%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%82%92%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2IRQ%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E5%8B%95%E4%BD%9C%E9%96%93%E3%81%AE%E6%99%82%E9%96%93%E5%B7%AE%E3%81%A8%E5%AE%9A%E7%BE%A9%E3%81%97%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%A8%E3%82%B5%E3%83%96%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E7%A7%92%E5%8D%98%E4%BD%8D%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%81%A7%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%E3%81%AE%E8%83%BD%E5%8A%9B%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3Ei.MX%208M%20Plus%E8%A3%BD%E5%93%81%2F%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%86%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3Ei.MX%208M%20Plus%E3%81%AF%E3%83%87%E3%83%A5%E3%82%A2%E3%83%ABGb%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A11%E3%81%A4%E3%81%AFTSN%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%80%81%E7%94%A3%E6%A5%AD%E7%94%A8%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E5%88%B6%E5%BE%A1%E3%81%AB%E3%81%AF%E7%B5%B1%E5%90%88%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E800%20MHz%E3%81%AEArm%20Cortex-M7%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A6%8F%E6%A0%BC%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3Ei.MX%208M%20%E3%83%97%E3%83%A9%E3%82%B9%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%81%3CSTRONG%20class%3D%22%22%3EIEEE%20802.1Qbv%20Time-Aware%20Shaper%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E802.1Qav%20Credit-Based%20Shaper%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3EIEEE%201588v2%20PTP%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%AE%9F%E8%A3%85%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E802.1Qbv-2015%3C%2FSTRONG%3E%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E802.3br%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%81%20%E3%81%9D%E3%81%97%E3%81%A6%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E802.1Qbu%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%97%E3%83%AA%E3%82%A8%E3%83%B3%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E9%96%A2%E9%80%A3%E3%81%AETSN%E9%96%A2%E6%95%B0%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%E3%83%86%E3%82%B9%E3%83%88%2F%E6%A4%9C%E8%A8%BC%E7%92%B0%E5%A2%83%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%0A%3CDIV%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A8%E3%83%83%E3%82%B8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3C%2FDIV%3E%0A%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E7%94%9F%E6%88%90%E3%83%BB%E8%A7%A3%E6%9E%90%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%80%81%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%E3%80%81%E5%90%8C%E6%9C%9F%E7%B2%BE%E5%BA%A6%E3%81%AE%E7%9B%A3%E8%A6%96%E3%82%92%E5%90%AB%E3%82%808M%20Plus%20TSN%E3%81%AE%E8%83%BD%E5%8A%9B%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AETSN%E3%83%86%E3%82%B9%E3%83%88%E7%92%B0%E5%A2%83%20i.MX%20%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%2F%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AE%E4%BE%8B%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A8%E3%83%83%E3%82%B8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%20%E2%80%94%20TSN%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E6%9C%80%E5%B0%8F%2F%E5%B9%B3%E5%9D%87%2F%E6%9C%80%E5%A4%A7%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%84%E3%83%8E%E3%83%BC%E3%83%88%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AF%E7%B4%84503%CE%BCs%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%20%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%E3%81%AF%E7%B4%84300%20ns%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%82%92%E5%90%AB%E3%82%80TSN%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E7%B5%B1%E8%A8%88%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%87%E3%83%A2%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3EAN13588%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3EGenAVB%2FTSN%E3%81%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E5%88%B6%E5%BE%A1%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A8%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E2%E3%83%9F%E3%83%AA%E7%A7%92%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%81%3CSTRONG%20class%3D%22%22%3E400%CE%BCs%E3%81%AE%E4%BA%88%E7%B4%84%2F%E4%BF%9D%E8%A8%BC%E5%88%B6%E5%BE%A1%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%81%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%80%81%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AE%E6%AD%A3%E7%A2%BA%E6%80%A7%E3%80%81%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E7%B5%B1%E8%A8%88%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%20802.1Qbv%20%E3%83%87%E3%83%A2%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3EAN13995%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E8M%20Plus%20i.MX%20%E3%82%92%E7%94%A8%E3%81%84%E3%81%9FTSN%20802.1Qbv%E3%81%AE%E5%AE%9F%E6%BC%94%E3%81%A8%E3%80%81%E6%99%82%E9%96%93%E8%AA%8D%E8%AD%98%E3%82%B7%E3%82%A7%E3%83%BC%E3%83%94%E3%83%B3%E3%82%B0%E3%81%8C%E5%9B%BA%E5%AE%9A%E3%83%AA%E3%83%94%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E7%94%A8%E3%81%84%E3%81%A6%E3%83%87%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8B%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AA%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81Linux%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3Etc%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%2F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3Etaprio%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Econfiguration%E3%81%AE%E4%BE%8B%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22mt-1%20flex%20justify-start%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82iMX8M%20Plus%20EVK%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%82%E6%83%85%E5%A0%B1%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3Ei.MX95%20EVK%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%85%AC%E5%BC%8F%E3%81%AA%E3%80%8C%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E6%80%A7%E8%83%BD%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%80%8D%E3%81%AF%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%89%BF%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81NXP%E3%81%AFi.MX95%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E4%B8%8A%E3%81%A7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%AE%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%82%92%E5%86%85%E9%83%A8%E3%81%A7%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%86%85%E9%83%A8%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E6%96%87%E6%9B%B8%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81cyclictest%E3%81%8A%E3%82%88%E3%81%B3EtherCAT%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E8%A9%95%E4%BE%A1%E3%81%AF%E3%80%81Linux%E4%B8%8A%E3%81%A7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A8%E3%83%83%E3%82%B8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8Bi.MX95%20LPDDR5%20EVK%E4%B8%8A%E3%81%A7%E5%AE%9F%E6%96%BDPREEMPT_RT%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%9F%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%816%E6%99%82%E9%96%93%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9NG%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E6%9C%80%E5%A4%A7%E5%91%A8%E6%9C%9F%E3%83%86%E3%82%B9%E3%83%88**%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7**%E7%B4%8438%CE%BCs%E3%82%84%E3%80%81EtherCAT%E3%81%AE%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%81%AB%E3%82%88%E3%82%8B%E6%9C%80%E5%A4%A7%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%E7%B4%8412%CE%BCs%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E6%80%A7%E8%83%BD%E3%81%AFBSP%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E6%A7%8B%E6%88%90%E3%80%81CPU%E5%88%86%E9%9B%A2%E3%80%81%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%89%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AB%E5%A4%A7%E3%81%8D%E3%81%8F%E4%BE%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%80%A4%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E4%BF%9D%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%9F%E5%88%B6%E9%99%90%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%8F%82%E7%85%A7%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%81%A8%E3%81%BF%E3%81%AA%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FREALTIMEEDGEUG.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FREALTIMEEDGEUG.pdf%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%83%99%E3%83%B3%E3%83%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%83%86%E3%82%B9%E3%83%88%E3%80%81%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9%E3%80%81rt_latency%E6%89%8B%E9%A0%86%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%E4%BB%A3%E7%90%86%E5%BA%97%E3%81%8B%E3%82%89%E3%81%AF%E3%80%81NXP%20i.MX95%20EVK%E3%81%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%84%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%85%AC%E5%BC%8F%E3%81%AA%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E7%8F%BE%E5%9C%A8%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E4%BC%9D%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E6%89%8B%E6%B3%95(%E4%BE%8B%3Acyclictest)%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%82%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E6%88%91%E3%80%85%E3%81%AE%E5%81%B4%E3%81%A7%E5%A4%9A%E5%B0%91%E3%81%AE%E6%B7%B7%E4%B9%B1%E3%82%92%E6%8B%9B%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%80%82%E6%A8%99%E6%BA%96%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%86%E3%82%B9%E3%83%88%E6%89%8B%E6%B3%95%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8B%E3%82%89%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9EVK%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E4%B8%8A%E3%81%A7%E5%86%85%E9%83%A8%E3%81%A7%E5%AE%9F%E6%96%BD%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%82%B9%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3ENXP%E3%81%AFi.MX95%20EVK%E3%81%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E6%80%A7%E8%83%BD(%E4%BE%8B%3A%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%80%81%E3%82%B8%E3%83%83%E3%82%BF%E3%83%BC)%E3%81%AE%E5%86%85%E9%83%A8%E6%B8%AC%E5%AE%9A%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E5%85%B1%E6%9C%89%E3%81%A7%E3%81%8D%E3%82%8B%E5%8F%82%E8%80%83%E3%82%84%E5%9F%BA%E6%BA%96%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AF%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%A7%8B%E6%88%90%E3%82%84%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%A4%89%E5%8B%95%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%AE%A1%E7%90%86%E3%81%95%E3%82%8C%E3%81%9F%E6%9D%A1%E4%BB%B6%E4%B8%8B%EF%BC%88%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEBSP%E3%80%81%E6%9C%80%E5%B0%8F%E8%B2%A0%E8%8D%B7%EF%BC%89%E3%81%A7%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%E3%83%A9%E3%82%A4%E3%83%B3%E7%B5%90%E6%9E%9C%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E5%88%9D%E6%9C%9F%E8%A9%95%E4%BE%A1%E3%81%AB%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%A0%E3%82%8D%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%8D%E9%96%8B%E3%81%BE%E3%81%A7%E4%BB%8A%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22hankwang_0-1784018178178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hankwang_0-1784018178178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hankwang_0-1784018178178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hankwang_0-1784018178178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392192i8697EA9F77E08565%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22hankwang_0-1784018178178.png%22%20alt%3D%22hankwang_0-1784018178178.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ehankwang_0-1784018178178.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3COL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fnxp1-my.sharepoint.com%2Fpersonal%2Fyiping_wang_nxp_com%2F_layouts%2F15%2Fviewer.aspx%3Fsourcedoc%3D%257b736ac7e0-3cb5-4ae3-9a58-f3f03bbf63bf%257d%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EREALTIMEEDGEUG%3C%2FA%3E%20(%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A8%E3%83%83%E3%82%B8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89)(%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FREALTIMEEDGEUG.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FREALTIMEEDGEUG.pdf%3C%2FA%3E)%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSTRONG%3E.%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A8%E3%83%83%E3%82%B8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2(%E6%9C%80%E3%82%82%E9%96%A2%E9%80%A3%E6%80%A7%E3%81%8C%E9%AB%98%E3%81%84)%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3ENXP%E3%81%AE%20%3CSTRONG%3EReal-Time%20Edge%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FSTRONG%3E%20%E3%81%AF%E5%85%AC%E5%BC%8F%E3%81%ABi.MX8M%20Plus%20EVK%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E5%90%AB%E3%81%BF%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EPREEMPT_RT%20Linux%3C%2FLI%3E%0A%3CLI%3ETSN%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%3C%2FLI%3E%0A%3CLI%3EIEEE%20802.1AS%20(gPTP)%20%E5%90%8C%E6%9C%9F%3C%2FLI%3E%0A%3CLI%3ETSN%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B7%E3%82%A7%E3%83%BC%E3%83%94%E3%83%B3%E3%82%B0%E3%81%A8%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FLI%3E%0A%3CLI%3EEtherCAT%E3%80%81OPC-UA%E3%80%81CAN%E9%96%A2%E9%80%A3%E3%81%AE%E7%94%A3%E6%A5%AD%E7%94%A8%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3C%2FLI%3E%0A%3CLI%3ECortex-A53%20%2B%20Cortex-M7%E3%82%92%E7%94%A8%E3%81%84%E3%81%9F%E7%95%B0%E7%A8%AE%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E5%8B%95%E4%BD%9C%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%86%85%E9%83%A8%E6%96%87%E6%9B%B8%20%3CA%20href%3D%22https%3A%2F%2Fnxp1-my.sharepoint.com%2Fpersonal%2Fyiping_wang_nxp_com%2F_layouts%2F15%2Fviewer.aspx%3Fsourcedoc%3D%257b736ac7e0-3cb5-4ae3-9a58-f3f03bbf63bf%257d%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EREALTIMEEDGEUG%3C%2FA%3E%20%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81Real-Time%20Edge%20Software%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0(TSN)%3C%2FLI%3E%0A%3CLI%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0Linux(PREEMPT_RT)%3C%2FLI%3E%0A%3CLI%3E%E7%B4%94%E7%B2%8B%E3%81%AARTOS%2F%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FLI%3E%0A%3CLI%3E%E5%88%91%E5%8B%99%E6%89%80%E3%81%AE%E4%BB%95%E5%88%87%E3%82%8A%3C%2FLI%3E%0A%3CLI%3E%E3%82%A4%E3%83%B3%E3%83%80%E3%82%B9%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3Ei.MX%208M%20Plus%20LPDDR4%20EVK%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3COL%20start%3D%222%22%3E%0A%3CLI%3ENXP%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%20%3CSTRONG%3EAN13995%20%E2%80%93%20i.MX%208M%20Plus%E3%82%92%E7%94%A8%E3%81%84%E3%81%9FTSN%20802.1Qbv%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AESix%20Pack%E8%B3%87%E6%96%99(PREEMPT_RT%2BTSN%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B)%3C%2FLI%3E%0A%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FP%3E%3CP%3E1%20%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A8%E3%83%83%E3%82%B8%20%E3%82%B7%E3%83%83%E3%82%AF%E3%82%B9%E3%83%91%E3%83%83%E3%82%AF%E3%81%AE%E7%B4%A0%E6%9D%90%3CBR%20%2F%3E2%20%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A8%E3%83%83%E3%82%B8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%20%E2%80%94%20TSN%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%3CBR%20%2F%3E3%20%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A8%E3%83%83%E3%82%B8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3CBR%20%2F%3E4%20Harpoon%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%20%E2%80%94%20rt%20%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3CBR%20%2F%3E5%20%E3%83%8F%E3%83%BC%E3%83%97%E3%83%BC%E3%83%B3%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%3CBR%20%2F%3E6%20AN13588%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
