Regarding 8M Plus Real time Accuracy
1,137 次查看
hankwang
Hi,  We would like to lean more about 8M Plus capabilities regarding its real-time applications. Are there any test reports or related materials available concerning TSN or real-time performance, or jitter?
1,075 次查看
yipingwang
Area Available material What it contains
Real-time CPU/RTOS latency Harpoon User’s Guide Measured real-time latencies on i.MX 8M Plus / Zephyr , including IRQ latency and task latency in ns. Example results: no-load IRQ latency min/avg/max/stddev = 625 / 796 / 11,125 / 1,798 ns ; task latency = 2,583 / 2,671 / 13,041 / 6,045 ns . Under Linux CPU + memory load, IRQ latency = 625 / 798 / 4,250 / 4,674 ns , and task latency = 2,583 / 2,670 / 14,333 / 10,407 ns .
Real-time benchmark method Harpoon User’s Guide — rt latency application Defines the benchmark as the time delta between hardware IRQ events and software actions, measured with a hardware timer and sub-microsecond precision.
TSN capability i.MX 8M Plus product / reference material i.MX 8M Plus includes dual Gb Ethernet, with one Ethernet supporting TSN, and uses the integrated 800 MHz Arm Cortex-M7 for industrial real-time control.
TSN hardware standards i.MX 8M Plus Reference Manual TSN support includes IEEE 802.1Qbv Time-Aware Shaper , 802.1Qav Credit-Based Shaper , IEEE 1588v2 PTP , and the Ethernet block implements 802.1Qbv-2015 , 802.3br , and 802.1Qbu frame preemption-related TSN functions.
TSN test / validation environment
Real-Time Edge User Guide
Describes a TSN test environment for evaluating i.MX 8M Plus TSN capabilities, including traffic generation/analysis and monitoring of latency, jitter, and synchronization accuracy.
TSN jitter / latency example Real-Time Edge User Guide — TSN endpoint sample app Provides TSN endpoint statistics including traffic latency min/mean/max and notes latency around 503 µs with latency jitter around 300 ns in the shown example.
TSN application demo AN13588 Demonstrates a GenAVB/TSN real-time control application. It describes a 2 ms cycle , a 400 µs reserved/guaranteed control-traffic window , and a statistics thread for scheduling, processing timing, traffic correctness, and latency.
TSN 802.1Qbv demo AN13995 Demonstrates TSN 802.1Qbv using i.MX 8M Plus and explains how time-aware shaping uses fixed repeating cycles to provide deterministic latency; it also includes Linux tc / taprio configuration examples.
7 回复数
1,124 次查看
hankwang
Our distributor informed us that there is currently no official performance report available for the NXP i.MX95 EVK regarding real-time performance or jitter.
However, they also provided documentation describing the testing methodology (e.g., cyclictest) for evaluating real-time latency.
This leads to some confusion on our side. Since a standardized testing methodology exists, we assume that such tests must have been performed internally—at least on the reference EVK platform.
Therefore, we would like to clarify:
  • Has NXP conducted any internal measurements of real-time performance (e.g., latency, jitter) on the i.MX95 EVK?
  • If so, are there any reference or baseline results that could be shared?
We understand that real-time performance may vary depending on system configuration and workload. However, even a baseline result under controlled conditions (e.g., default BSP, minimal load) would be very helpful for initial evaluation.
Thank you for your support.
1,110 次查看
yipingwang
We understand that no public "real-time performance report" has been officially released for i.MX95 EVK. However, NXP does internally perform real-time benchmarking on i.MX95 platforms. Internal benchmark documents indicate that cyclictest and EtherCAT performance evaluations have been executed on i.MX95 LPDDR5 EVKs running Real-Time Edge software with PREEMPT_RT Linux. Reported examples include a maximum cyclictest latency of approximately 38 µs during a 6-hour stress-ng test and EtherCAT filtered maximum jitter of approximately 12 µs under the documented test conditions. Because real-time performance depends strongly on BSP version, kernel configuration, CPU isolation, workload, and network traffic, these values should be considered reference measurements rather than guaranteed application-level limits.
as supported benchmarking platforms and provide detailed cyclictest, stress, and rt_latency procedures.
1,085 次查看
hankwang
@yipingwang
Thank you for providing the information. Could you also please provide us with information about the iMX8M Plus EVK?
Thanks.
1,076 次查看
yipingwang
1,061 次查看
hankwang
@yipingwangThank you very much for the information you provided.
1,125 次查看
yipingwang
  1. REALTIMEEDGEUG (Real-Time Edge Software User Guide) (https://www.nxp.com/docs/en/user-guide/REALTIMEEDGEUG.pdf)
. Real-Time Edge Software (most relevant)
NXP's Real-Time Edge Software officially supports the i.MX8M Plus EVK and includes:
  • PREEMPT_RT Linux
  • TSN stack
  • IEEE 802.1AS (gPTP) synchronization
  • TSN traffic shaping and scheduling
  • EtherCAT, OPC-UA, CAN-related industrial protocols
  • Heterogeneous real-time operation using Cortex-A53 + Cortex-M7
The internal document REALTIMEEDGEUG states that Real-Time Edge Software provides:
  • Real-time networking (TSN)
  • Real-time Linux (PREEMPT_RT)
  • Pure RTOS/Bare-metal options
  • Jailhouse partitioning
  • Industrial protocol support
Support for i.MX 8M Plus LPDDR4 EVK
  1. NXP Application Note AN13995 – TSN 802.1Qbv Demonstration using i.MX 8M Plus
  2. The Real-Time Edge Six Pack materials describing PREEMPT_RT + TSN support
410 次查看
zhijie
How to download:
1 Real-Time Edge Six Pack materials
2 Real-Time Edge User Guide — TSN endpoint sample app
3 Real-Time Edge User Guide
4 Harpoon User’s Guide — rt latency application
5 Harpoon User’s Guide
6 AN13588
%3CLINGO-SUB%20id%3D%22lingo-sub-2394723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%85%B3%E4%BA%8E8M%2B%E5%AE%9E%E6%97%B6%E7%B2%BE%E5%BA%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E4%BB%AC%E6%83%B3%E6%9B%B4%E5%A4%9A%E5%9C%B0%E4%BA%86%E8%A7%A3%208M%20Plus%20%E5%9C%A8%E5%AE%9E%E6%97%B6%E5%BA%94%E7%94%A8%E6%96%B9%E9%9D%A2%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E5%85%B3%E4%BA%8ETSN%E3%80%81%E5%AE%9E%E6%97%B6%E6%80%A7%E8%83%BD%E6%88%96%E6%8A%96%E5%8A%A8%E6%96%B9%E9%9D%A2%E7%9A%84%E6%B5%8B%E8%AF%95%E6%8A%A5%E5%91%8A%E6%88%96%E7%9B%B8%E5%85%B3%E8%B5%84%E6%96%99%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2394723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22overflow-x-auto%20rounded-lg%20border%20border-border%20bg-background%22%3E%0A%3CTABLE%3E%0A%3CTHEAD%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTH%20class%3D%22px-2%20py-1.5%20text-left%20font-semibold%22%3E%E9%9D%A2%E7%A7%AF%3C%2FTH%3E%0A%3CTH%20class%3D%22px-2%20py-1.5%20text-left%20font-semibold%22%3E%E5%8F%AF%E7%94%A8%E6%9D%90%E6%96%99%3C%2FTH%3E%0A%3CTH%20class%3D%22px-2%20py-1.5%20text-left%20font-semibold%22%3E%E5%AE%83%E5%8C%85%E5%90%AB%E4%BB%80%E4%B9%88%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E5%AE%9E%E6%97%B6%20CPU%2FRTOS%20%E5%BB%B6%E8%BF%9F%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3E%E9%B1%BC%E5%8F%89%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E6%B5%8B%E9%87%8F%E5%AE%9E%E6%97%B6%E5%BB%B6%E8%BF%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3Ei.MX%208M%20Plus%20%2F%20Zephyr%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%8C%85%E6%8B%AC%20IRQ%20%E5%BB%B6%E8%BF%9F%E5%92%8C%E4%BB%BB%E5%8A%A1%E5%BB%B6%E8%BF%9F%EF%BC%88%E5%8D%95%E4%BD%8D%EF%BC%9A%E7%BA%B3%E7%A7%92%EF%BC%89%E3%80%82%E7%A4%BA%E4%BE%8B%E7%BB%93%E6%9E%9C%EF%BC%9A%E7%A9%BA%E8%BD%BD%20IRQ%20%E5%BB%B6%E8%BF%9F%E6%9C%80%E5%B0%8F%E5%80%BC%2F%E5%B9%B3%E5%9D%87%E5%80%BC%2F%E6%9C%80%E5%A4%A7%E5%80%BC%2F%E6%A0%87%E5%87%86%E5%B7%AE%20%3D%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E625%20%2F%20796%20%2F%2011%2C125%20%2F%201%2C798%20ns%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E4%BB%BB%E5%8A%A1%E5%BB%B6%E8%BF%9F%20%3D%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E2%2C583%20%2F%202%2C671%20%2F%2013%2C041%20%2F%206%2C045%20ns%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%82%E5%9C%A8%20Linux%20%E7%B3%BB%E7%BB%9F%E4%B8%8B%EF%BC%8CCPU%20%2B%20%E5%86%85%E5%AD%98%E8%B4%9F%E8%BD%BD%EF%BC%8CIRQ%20%E5%BB%B6%E8%BF%9F%20%3D%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E625%20%2F%20798%20%2F%204%2C250%20%2F%204%2C674%20ns%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%8C%E4%BB%BB%E5%8A%A1%E5%BB%B6%E8%BF%9F%20%3D%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E2%2C583%20%2F%202%2C670%20%2F%2014%2C333%20%2F%2010%2C407%20ns%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E5%AE%9E%E6%97%B6%E5%9F%BA%E5%87%86%E6%B5%8B%E8%AF%95%E6%96%B9%E6%B3%95%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3EHarpoon%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%20%E2%80%94%20%E5%AE%9E%E6%97%B6%E5%BB%B6%E8%BF%9F%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E5%B0%86%E5%9F%BA%E5%87%86%E5%AE%9A%E4%B9%89%E4%B8%BA%E7%A1%AC%E4%BB%B6%20IRQ%20%E4%BA%8B%E4%BB%B6%E4%B8%8E%E8%BD%AF%E4%BB%B6%E6%93%8D%E4%BD%9C%E4%B9%8B%E9%97%B4%E7%9A%84%E6%97%B6%E9%97%B4%E5%B7%AE%EF%BC%8C%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%E8%AE%A1%E6%97%B6%E5%99%A8%E4%BB%A5%E4%BA%9A%E5%BE%AE%E7%A7%92%E7%B2%BE%E5%BA%A6%E8%BF%9B%E8%A1%8C%E6%B5%8B%E9%87%8F%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%20%E8%83%BD%E5%8A%9B%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3Ei.MX%208M%20Plus%20%E4%BA%A7%E5%93%81%2F%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3Ei.MX%208M%20Plus%20%E5%8C%85%E5%90%AB%E5%8F%8C%E5%8D%83%E5%85%86%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%E6%94%AF%E6%8C%81%20TSN%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E9%9B%86%E6%88%90%E5%BC%8F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E800%20MHz%20Arm%20Cortex-M7%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E7%94%A8%E4%BA%8E%E5%B7%A5%E4%B8%9A%E5%AE%9E%E6%97%B6%E6%8E%A7%E5%88%B6%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%E7%A1%AC%E4%BB%B6%E6%A0%87%E5%87%86%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3Ei.MX%208M%20Plus%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%E6%94%AF%E6%8C%81%E5%8C%85%E6%8B%AC%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3EIEEE%20802.1Qbv%20%E6%97%B6%E9%97%B4%E6%84%9F%E7%9F%A5%E6%95%B4%E5%BD%A2%E5%99%A8%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E802.1Qav%20%E5%9F%BA%E4%BA%8E%E4%BF%A1%E7%94%A8%E7%9A%84%E6%95%B4%E5%BD%A2%E8%80%85%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3EIEEE%201588v2%20PTP%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%A8%A1%E5%9D%97%E5%AE%9E%E7%8E%B0%E4%BA%86%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E802.1Qbv-2015%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E802.3br%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%8C%20%E5%92%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E802.1Qbu%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E4%B8%8E%E5%B8%A7%E6%8A%A2%E5%8D%A0%E7%9B%B8%E5%85%B3%E7%9A%84TSN%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%20%E6%B5%8B%E8%AF%95%2F%E9%AA%8C%E8%AF%81%E7%8E%AF%E5%A2%83%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%0A%3CDIV%3E%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E8%AE%A1%E7%AE%97%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FDIV%3E%0A%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E6%8F%8F%E8%BF%B0%E4%BA%86%E7%94%A8%E4%BA%8E%E8%AF%84%E4%BC%B0%20i.MX%208M%20Plus%20TSN%20%E5%8A%9F%E8%83%BD%E7%9A%84%20TSN%20%E6%B5%8B%E8%AF%95%E7%8E%AF%E5%A2%83%EF%BC%8C%E5%8C%85%E6%8B%AC%E6%B5%81%E9%87%8F%E7%94%9F%E6%88%90%2F%E5%88%86%E6%9E%90%E4%BB%A5%E5%8F%8A%E5%AF%B9%E5%BB%B6%E8%BF%9F%E3%80%81%E6%8A%96%E5%8A%A8%E5%92%8C%E5%90%8C%E6%AD%A5%E7%B2%BE%E5%BA%A6%E7%9A%84%E7%9B%91%E6%8E%A7%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%E6%8A%96%E5%8A%A8%2F%E5%BB%B6%E8%BF%9F%E7%A4%BA%E4%BE%8B%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3E%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%20%E2%80%94%20TSN%20%E7%AB%AF%E7%82%B9%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E6%8F%90%E4%BE%9B%20TSN%20%E7%AB%AF%E7%82%B9%E7%BB%9F%E8%AE%A1%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%8C%85%E6%8B%AC%E6%B5%81%E9%87%8F%E5%BB%B6%E8%BF%9F%E6%9C%80%E5%B0%8F%E5%80%BC%2F%E5%B9%B3%E5%9D%87%E5%80%BC%2F%E6%9C%80%E5%A4%A7%E5%80%BC%E5%92%8C%E5%A4%87%E6%B3%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%E5%BB%B6%E8%BF%9F%E7%BA%A6%E4%B8%BA%20503%20%E5%BE%AE%E7%A7%92%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%92%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E%E5%BB%B6%E8%BF%9F%E6%8A%96%E5%8A%A8%E7%BA%A6%E4%B8%BA%20300%20%E7%BA%B3%E7%A7%92%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%9C%A8%E6%89%80%E7%A4%BA%E7%A4%BA%E4%BE%8B%E4%B8%AD%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%20%E5%BA%94%E7%94%A8%E6%BC%94%E7%A4%BA%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3EAN13588%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E6%BC%94%E7%A4%BA%20GenAVB%2FTSN%20%E5%AE%9E%E6%97%B6%E6%8E%A7%E5%88%B6%E5%BA%94%E7%94%A8%E3%80%82%E5%AE%83%E6%8F%8F%E8%BF%B0%E4%BA%86%E4%B8%80%E4%B8%AA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E2%E6%AF%AB%E7%A7%92%E5%91%A8%E6%9C%9F%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%8C%E4%B8%80%E4%B8%AA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20class%3D%22%22%3E400%20%E5%BE%AE%E7%A7%92%E9%A2%84%E7%95%99%2F%E4%BF%9D%E8%AF%81%E7%9A%84%E6%8E%A7%E5%88%B6%E6%B5%81%E9%87%8F%E7%AA%97%E5%8F%A3%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E4%BB%A5%E5%8F%8A%E4%B8%80%E4%B8%AA%E7%94%A8%E4%BA%8E%E8%B0%83%E5%BA%A6%E3%80%81%E5%A4%84%E7%90%86%E6%97%B6%E9%97%B4%E3%80%81%E6%B5%81%E9%87%8F%E6%AD%A3%E7%A1%AE%E6%80%A7%E5%92%8C%E5%BB%B6%E8%BF%9F%E7%9A%84%E7%BB%9F%E8%AE%A1%E7%BA%BF%E7%A8%8B%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20class%3D%22%22%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3ETSN%20802.1Qbv%20%E6%BC%94%E7%A4%BA%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%3CSTRONG%20class%3D%22%22%3EAN13995%3C%2FSTRONG%3E%3C%2FTD%3E%0A%3CTD%20class%3D%22px-2%20py-1.5%22%3E%E6%BC%94%E7%A4%BA%E4%BA%86%E4%BD%BF%E7%94%A8%20i.MX%208M%20Plus%20%E7%9A%84%20TSN%20802.1Qbv%EF%BC%8C%E5%B9%B6%E8%A7%A3%E9%87%8A%E4%BA%86%E6%97%B6%E9%97%B4%E6%84%9F%E7%9F%A5%E6%95%B4%E5%BD%A2%E6%8A%80%E6%9C%AF%E5%A6%82%E4%BD%95%E5%88%A9%E7%94%A8%E5%9B%BA%E5%AE%9A%E7%9A%84%E9%87%8D%E5%A4%8D%E5%91%A8%E6%9C%9F%E6%9D%A5%E6%8F%90%E4%BE%9B%E7%A1%AE%E5%AE%9A%E6%80%A7%E7%9A%84%E5%BB%B6%E8%BF%9F%EF%BC%9B%E5%AE%83%E8%BF%98%E5%8C%85%E5%90%AB%20Linux%20%E7%89%88%E6%9C%AC%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3Etc%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%2F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3Etaprio%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E9%85%8D%E7%BD%AE%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22mt-1%20flex%20justify-start%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E4%BF%A1%E6%81%AF%E3%80%82%E8%AF%B7%E9%97%AE%E6%82%A8%E8%83%BD%E5%90%A6%E4%B9%9F%E5%90%91%E6%88%91%E4%BB%AC%E6%8F%90%E4%BE%9B%E6%9C%89%E5%85%B3%20iMX8M%20Plus%20EVK%20%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394753%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%E6%88%91%E4%BB%AC%E4%BA%86%E8%A7%A3%E5%88%B0%EF%BC%8Ci.MX95%20EVK%20%E5%B0%9A%E6%9C%AA%E6%AD%A3%E5%BC%8F%E5%8F%91%E5%B8%83%E4%BB%BB%E4%BD%95%E5%85%AC%E5%BC%80%E7%9A%84%E2%80%9C%E5%AE%9E%E6%97%B6%E6%80%A7%E8%83%BD%E6%8A%A5%E5%91%8A%E2%80%9D%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8CNXP%20%E5%86%85%E9%83%A8%E7%A1%AE%E5%AE%9E%E5%AF%B9%20i.MX95%20%E5%B9%B3%E5%8F%B0%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%AE%9E%E6%97%B6%E5%9F%BA%E5%87%86%E6%B5%8B%E8%AF%95%E3%80%82%E5%86%85%E9%83%A8%E5%9F%BA%E5%87%86%E6%B5%8B%E8%AF%95%E6%96%87%E6%A1%A3%E8%A1%A8%E6%98%8E%EF%BC%8C%E5%B7%B2%E5%9C%A8%E8%BF%90%E8%A1%8C%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E8%BD%AF%E4%BB%B6%E5%92%8C%20PREEMPT_RT%20Linux%20%E7%9A%84%20i.MX95%20LPDDR5%20EVK%20%E4%B8%8A%E6%89%A7%E8%A1%8C%E4%BA%86%20cyclictest%20%E5%92%8C%20EtherCAT%20%E6%80%A7%E8%83%BD%E8%AF%84%E4%BC%B0%E3%80%82%E6%8A%A5%E5%91%8A%E7%9A%84%E4%BE%8B%E5%AD%90%E5%8C%85%E6%8B%AC%EF%BC%9A%E5%9C%A8%206%20%E5%B0%8F%E6%97%B6%E7%9A%84%E5%8E%8B%E5%8A%9B%E6%B5%8B%E8%AF%95%E6%9C%9F%E9%97%B4%EF%BC%8C%E5%BE%AA%E7%8E%AF%E6%B5%8B%E8%AF%95%E7%9A%84%E6%9C%80%E5%A4%A7%E5%BB%B6%E8%BF%9F%E7%BA%A6%E4%B8%BA%2038%20%C2%B5s%EF%BC%9B%E5%9C%A8%E8%AE%B0%E5%BD%95%E7%9A%84%E6%B5%8B%E8%AF%95%E6%9D%A1%E4%BB%B6%E4%B8%8B%EF%BC%8CEtherCAT%20%E6%BB%A4%E6%B3%A2%E5%90%8E%E7%9A%84%E6%9C%80%E5%A4%A7%E6%8A%96%E5%8A%A8%E7%BA%A6%E4%B8%BA%2012%20%C2%B5s%E3%80%82%E7%94%B1%E4%BA%8E%E5%AE%9E%E6%97%B6%E6%80%A7%E8%83%BD%E5%BE%88%E5%A4%A7%E7%A8%8B%E5%BA%A6%E4%B8%8A%E5%8F%96%E5%86%B3%E4%BA%8E%20BSP%20%E7%89%88%E6%9C%AC%E3%80%81%E5%86%85%E6%A0%B8%E9%85%8D%E7%BD%AE%E3%80%81CPU%20%E9%9A%94%E7%A6%BB%E3%80%81%E5%B7%A5%E4%BD%9C%E8%B4%9F%E8%BD%BD%E5%92%8C%E7%BD%91%E7%BB%9C%E6%B5%81%E9%87%8F%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%BF%99%E4%BA%9B%E5%80%BC%E5%BA%94%E8%A2%AB%E8%A7%86%E4%B8%BA%E5%8F%82%E8%80%83%E6%B5%8B%E9%87%8F%E5%80%BC%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E4%BF%9D%E8%AF%81%E7%9A%84%E5%BA%94%E7%94%A8%E7%BA%A7%E9%99%90%E5%88%B6%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FREALTIMEEDGEUG.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FREALTIMEEDGEUG.pdf%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%E4%BD%9C%E4%B8%BA%E6%94%AF%E6%8C%81%E7%9A%84%E5%9F%BA%E5%87%86%E6%B5%8B%E8%AF%95%E5%B9%B3%E5%8F%B0%EF%BC%8C%E5%B9%B6%E6%8F%90%E4%BE%9B%E8%AF%A6%E7%BB%86%E7%9A%84%E5%BE%AA%E7%8E%AF%E6%B5%8B%E8%AF%95%E3%80%81%E5%8E%8B%E5%8A%9B%E6%B5%8B%E8%AF%95%E5%92%8C%20rt_latency%20%E6%B5%8B%E8%AF%95%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394738%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%E6%88%91%E4%BB%AC%E7%9A%84%E4%BB%A3%E7%90%86%E5%95%86%E5%91%8A%E7%9F%A5%E6%88%91%E4%BB%AC%EF%BC%8C%E7%9B%AE%E5%89%8D%E8%BF%98%E6%B2%A1%E6%9C%89%E5%85%B3%E4%BA%8E%20NXP%20i.MX95%20EVK%20%E5%AE%9E%E6%97%B6%E6%80%A7%E8%83%BD%E6%88%96%E6%8A%96%E5%8A%A8%E7%9A%84%E5%AE%98%E6%96%B9%E6%80%A7%E8%83%BD%E6%8A%A5%E5%91%8A%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E4%BB%96%E4%BB%AC%E8%BF%98%E6%8F%90%E4%BE%9B%E4%BA%86%E6%8F%8F%E8%BF%B0%E8%AF%84%E4%BC%B0%E5%AE%9E%E6%97%B6%E5%BB%B6%E8%BF%9F%E7%9A%84%E6%B5%8B%E8%AF%95%E6%96%B9%E6%B3%95%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%BE%AA%E7%8E%AF%E6%B5%8B%E8%AF%95%EF%BC%89%E7%9A%84%E6%96%87%E6%A1%A3%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E5%AF%BC%E8%87%B4%E6%88%91%E4%BB%AC%E8%BF%99%E8%BE%B9%E6%9C%89%E4%BA%9B%E5%9B%B0%E6%83%91%E3%80%82%E7%94%B1%E4%BA%8E%E5%AD%98%E5%9C%A8%E6%A0%87%E5%87%86%E5%8C%96%E7%9A%84%E6%B5%8B%E8%AF%95%E6%96%B9%E6%B3%95%EF%BC%8C%E6%88%91%E4%BB%AC%E5%81%87%E8%AE%BE%E6%AD%A4%E7%B1%BB%E6%B5%8B%E8%AF%95%E4%B8%80%E5%AE%9A%E5%B7%B2%E5%9C%A8%E5%86%85%E9%83%A8%E6%89%A7%E8%A1%8C%E8%BF%87%E2%80%94%E2%80%94%E8%87%B3%E5%B0%91%E5%9C%A8%E5%8F%82%E8%80%83%20EVK%20%E5%B9%B3%E5%8F%B0%E4%B8%8A%E6%89%A7%E8%A1%8C%E8%BF%87%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%AC%E6%83%B3%E6%BE%84%E6%B8%85%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3ENXP%20%E6%98%AF%E5%90%A6%E5%AF%B9%20i.MX95%20EVK%20%E8%BF%9B%E8%A1%8C%E8%BF%87%E4%BB%BB%E4%BD%95%E5%AE%9E%E6%97%B6%E6%80%A7%E8%83%BD%EF%BC%88%E4%BE%8B%E5%A6%82%E5%BB%B6%E8%BF%9F%E3%80%81%E6%8A%96%E5%8A%A8%EF%BC%89%E7%9A%84%E5%86%85%E9%83%A8%E6%B5%8B%E9%87%8F%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E5%A6%82%E6%9E%9C%E5%8F%AF%E4%BB%A5%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%82%E8%80%83%E7%BB%93%E6%9E%9C%E6%88%96%E5%9F%BA%E5%87%86%E7%BB%93%E6%9E%9C%E5%8F%AF%E4%BB%A5%E5%88%86%E4%BA%AB%EF%BC%9F%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BA%86%E8%A7%A3%E5%88%B0%EF%BC%8C%E5%AE%9E%E6%97%B6%E6%80%A7%E8%83%BD%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%9B%A0%E7%B3%BB%E7%BB%9F%E9%85%8D%E7%BD%AE%E5%92%8C%E5%B7%A5%E4%BD%9C%E8%B4%9F%E8%BD%BD%E8%80%8C%E5%BC%82%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E5%8D%B3%E4%BD%BF%E6%98%AF%E5%8F%97%E6%8E%A7%E6%9D%A1%E4%BB%B6%E4%B8%8B%E7%9A%84%E5%9F%BA%E5%87%86%E7%BB%93%E6%9E%9C%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E9%BB%98%E8%AE%A4%20BSP%EF%BC%8C%E6%9C%80%E5%B0%8F%E8%B4%9F%E8%BD%BD%EF%BC%89%E5%AF%B9%E4%BA%8E%E5%88%9D%E6%AD%A5%E8%AF%84%E4%BC%B0%E4%B9%9F%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22hankwang_0-1784018178178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hankwang_0-1784018178178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hankwang_0-1784018178178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22hankwang_0-1784018178178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392192i8697EA9F77E08565%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22hankwang_0-1784018178178.png%22%20alt%3D%22hankwang_0-1784018178178.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ehankwang_0-1784018178178.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394737%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3COL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fnxp1-my.sharepoint.com%2Fpersonal%2Fyiping_wang_nxp_com%2F_layouts%2F15%2Fviewer.aspx%3Fsourcedoc%3D%257b736ac7e0-3cb5-4ae3-9a58-f3f03bbf63bf%257d%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EREALTIMEEDGEUG%3C%2FA%3E%20%EF%BC%88%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E8%BD%AF%E4%BB%B6%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%EF%BC%89%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FREALTIMEEDGEUG.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FREALTIMEEDGEUG.pdf%3C%2FA%3E%20%EF%BC%89%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSTRONG%3E%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E8%BD%AF%E4%BB%B6%EF%BC%88%E6%9C%80%E7%9B%B8%E5%85%B3%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%E7%9A%84%3CSTRONG%3E%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E8%BD%AF%E4%BB%B6%3C%2FSTRONG%3E%E6%AD%A3%E5%BC%8F%E6%94%AF%E6%8C%81%20i.MX8M%20Plus%20EVK%EF%BC%8C%E5%B9%B6%E5%8C%85%E5%90%AB%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EPREEMPT_RT%20Linux%3C%2FLI%3E%0A%3CLI%3ETSN%20%E5%8D%8F%E8%AE%AE%E6%A0%88%3C%2FLI%3E%0A%3CLI%3EIEEE%20802.1AS%20(gPTP)%20%E5%90%8C%E6%AD%A5%3C%2FLI%3E%0A%3CLI%3ETSN%E6%B5%81%E9%87%8F%E6%95%B4%E5%BD%A2%E5%92%8C%E8%B0%83%E5%BA%A6%3C%2FLI%3E%0A%3CLI%3EEtherCAT%E3%80%81OPC-UA%E3%80%81CAN%20%E7%9B%B8%E5%85%B3%E5%B7%A5%E4%B8%9A%E5%8D%8F%E8%AE%AE%3C%2FLI%3E%0A%3CLI%3E%E4%BD%BF%E7%94%A8%20Cortex-A53%20%2B%20Cortex-M7%20%E7%9A%84%E5%BC%82%E6%9E%84%E5%AE%9E%E6%97%B6%E6%93%8D%E4%BD%9C%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%86%85%E9%83%A8%E6%96%87%E4%BB%B6%3CA%20href%3D%22https%3A%2F%2Fnxp1-my.sharepoint.com%2Fpersonal%2Fyiping_wang_nxp_com%2F_layouts%2F15%2Fviewer.aspx%3Fsourcedoc%3D%257b736ac7e0-3cb5-4ae3-9a58-f3f03bbf63bf%257d%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EREALTIMEEDGEUG%3C%2FA%3E%E6%8C%87%E5%87%BA%EF%BC%8C%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E8%BD%AF%E4%BB%B6%E6%8F%90%E4%BE%9B%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%AE%9E%E6%97%B6%E7%BD%91%E7%BB%9C%EF%BC%88TSN%EF%BC%89%3C%2FLI%3E%0A%3CLI%3E%E5%AE%9E%E6%97%B6%20Linux%20(PREEMPT_RT)%3C%2FLI%3E%0A%3CLI%3E%E7%BA%AFRTOS%2F%E8%A3%B8%E6%9C%BA%E9%80%89%E9%A1%B9%3C%2FLI%3E%0A%3CLI%3E%E7%9B%91%E7%8B%B1%E9%9A%94%E6%96%AD%3C%2FLI%3E%0A%3CLI%3E%E5%B7%A5%E4%B8%9A%E5%8D%8F%E8%AE%AE%E6%94%AF%E6%8C%81%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E6%94%AF%E6%8C%81%20i.MX%208M%20Plus%20LPDDR4%20EVK%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3COL%20start%3D%222%22%3E%0A%3CLI%3ENXP%20%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%3CSTRONG%3EAN13995%20%E2%80%93%20%E4%BD%BF%E7%94%A8%20i.MX%208M%20Plus%20%E8%BF%9B%E8%A1%8C%20TSN%20802.1Qbv%20%E6%BC%94%E7%A4%BA%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3E%E5%AE%9E%E6%97%B6%E4%BC%98%E5%8A%BF%E4%BA%A7%E5%93%81%E6%A6%82%E8%A7%88%E6%9D%90%E6%96%99%E4%B8%AD%E6%8F%8F%E8%BF%B0%E4%BA%86%20PREEMPT_RT%20%2B%20TSN%20%E6%94%AF%E6%8C%81%3C%2FLI%3E%0A%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2411968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Regarding%208M%20Plus%20Real%20time%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2411968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%8B%E8%BD%BD%E6%96%B9%E5%BC%8F%EF%BC%9A%3C%2FP%3E%3CP%3E1%20Real-Time%20Edge%20%E4%BA%A7%E5%93%81%E6%A6%82%E8%A7%88%20materials%3CBR%20%2F%3E2%20%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%20%E2%80%94%20TSN%20%E7%AB%AF%E7%82%B9%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E3%20%E5%AE%9E%E6%97%B6%E8%BE%B9%E7%BC%98%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3CBR%20%2F%3E4.%20Harpoon%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%20%E2%80%94%20%E5%AE%9E%E6%97%B6%E5%BB%B6%E8%BF%9F%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E5.%20%E9%B1%BC%E5%8F%89%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3CBR%20%2F%3E6%20AN13588%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
