Reg: Mouse/Touch not detected in QT application
2,640 次查看
vishvapathi
Hi All,
When i run QT application i am getting following error
$./sample -qws
Could not read calibration: "/etc/pointercal"
QWSTslibMouseHandlerPrivate: ts_open() failed with error: 'No such file or dire'
Attached export variables for reference.
DaianeAngolini
Raybiztech
winstonrodrigues
标签 (2)
1,909 次查看
daiane_angolini
You need to calibrate your device.
Do you have xinput_calibrator_once on your rootfs?
1,909 次查看
vishvapathi
No.. There is no xinput_calibrator_once in my rootfs and there is no pointercal in my /etc....
1,909 次查看
daiane_angolini
Yes, and if you´re using TSLIB calibrator, you may not want xinput_calibrator... Sorry for my confusion.
for tslib I think it´s /ts_calibrate
pointercal is a file that will be created by the calibrator binary. So, if you don´t have it, your system is not calibrated.
You may try to use an example one from some other source, but the recommended is use the calibrator app and create your own pointercal
