Reg: Driver updation
1,293 次查看
vishvapathi
Contributor V
          I have a doubt. When we select driver from LTIB and compile it changes the uImage or updations are made in rootfs??
Suppose i selected Package list-->Freescale Multimedia plugins/codes -->gst-fsl-plugins and complied the ltib.
After image is completly built should i update uImage or rootfs in my sdcard???
plz advice...
DaianeAngolini
chandrasekarkanniappan
Raybiztech
标签 (2)
1,180 次查看
Raybiztech
Contributor V
Hi Vishvapathi Karnan,
     After ltib completes building, /home/user/ltib/rootfs will be updated. Copy this rootfs with super user permissions to the sdcard.
Thanks & Regards,
RBT
1,180 次查看
vishvapathi
Contributor V
I had this doubt becoz i am using Marsboard, and uImage is created by using separate set of files, not LTIB.
so i can update only the rootfs, no need to update uImage/uboot right?
1,180 次查看
Raybiztech
Contributor V
     As you are building gst-fsl-plugins package through ltib, rootfs will be updated automatically. So you can use that rootfs with your existing uImage and uBoot.
Thanks & Regards,
RBT
