Reduce the temperature of imx6d
1,065 次查看
haitaochen
hello
      If we want to reduce the temperature of imx6d .  what should we do? Now we reduce the Clock frequency of GPU . That we got the desired temperature. But its performance is so bad. Is there have any good way to lower the temperature without sacrificing performance?
962 次查看
Yuri
  You may look at section 4 (Reducing Power Consumption) of app note
AN4509 (i.MX 6Dual/6Quad Power Consumption Measurement)
https://cache.freescale.com/files/32bit/doc/app_note/AN4509.pdf
 Perhaps it makes sense to apply heat sink. You may look at app note AN4579
(i.MX 6 Series Thermal Management Guidelines)
http://cache.freescale.com/files/32bit/doc/app_note/AN4579.pdf
Yuri
