Record android system audio
5,260 次查看
MustafaMunir
I want to record android system audio output on file. On Linux, I have configure a .asoundrc file in my home directory to achieve this. That allows me to record system audio as a wave file on disk.
Is the same mechanism possible with android for i.MX53 ? Does alsa in android reads configuration from /system/etc/asound.conf ? or its configuration is simply hard coded in alsa source.
Mustafa
标签 (3)
3,500 次查看
RafaelThomasGoz
Here it is:
state.imx3stack {
    control.1 {
        comment.access 'read write'
        comment.type ENUMERATED
        comment.count 1
        comment.item.0 '0dB'
        comment.item.1 '20dB'
        comment.item.2 '30dB'
        comment.item.3 '40dB'
        iface MIXER
        name 'MIC GAIN'
        value '0dB'
    control.2 {
        comment.type INTEGER
        comment.count 2
        comment.range '0 - 15'
        iface MIXER
        name 'Capture Volume'
        value.0 15
        value.1 15
    control.3 {
        comment.count 1
        comment.item.0 'No Change'
        comment.item.1 'Reduced by 6dB'
        iface MIXER
        name 'Capture Vol Reduction'
        value 'No Change'
    control.4 {
        comment.count 2
        comment.range '0 - 192'
        iface MIXER
        name 'Playback Volume'
        value.0 192
        value.1 192
    control.5 {
        comment.count 2
        comment.range '0 - 127'
        iface MIXER
        name 'Headphone Volume'
        value.0 127
        value.1 127
    control.6 {
        comment.count 1
        comment.item.0 DAC
        comment.item.1 LINE_IN
        iface MIXER
        name 'DAC Mux'
        value DAC
    control.7 {
        comment.count 1
        comment.item.0 MIC_IN
        iface MIXER
        name 'ADC Mux'
        value LINE_IN
    control.8 {
        comment.count 1
        comment.item.0 disable
        comment.item.1 '32KHz'
        comment.item.2 '44.1KHz'
        comment.item.3 '48KHz'
        comment.item.4 '96KHz'
        iface MIXER
        name ASRC
        value disable
    control.9 {
        comment.count 1
        comment.item.0 off
        comment.item.1 on
        iface MIXER
        name 'Jack Function'
        value on
    control.10 {
        comment.count 1
        comment.item.0 off
        comment.item.1 on
        iface MIXER
        name 'Speaker Function'
        value on
    control.11 {
        comment.count 1
        comment.item.0 off
        comment.item.1 on
        iface MIXER
        name 'Line In Function'
        value on
state.imx3stackspdif {
    control.1 {
        comment.count 1
        comment.item.0 off
        comment.item.1 on
        iface MIXER
        value on
6 回复数
3,500 次查看
RafaelThomasGoz
Well i have tested with an asound.conf and it seems to change the alsa configurations. However for some reason it doesn't get effective until android plays any audio once.
3,500 次查看
MustafaMunir
If that’s the case, I might be making some mistake in asound.conf. It would be great if you can share your asound.conf and I can test that on my Platform.
3,501 次查看
RafaelThomasGoz
Here it is:
state.imx3stack {
    control.1 {
        comment.count 1
        iface MIXER
        name 'MIC GAIN'
        value '0dB'
    control.2 {
        comment.count 2
        iface MIXER
        value.0 15
        value.1 15
    control.3 {
        comment.count 1
        iface MIXER
        value 'No Change'
    control.4 {
        comment.count 2
        iface MIXER
        value.0 192
        value.1 192
    control.5 {
        comment.count 2
        iface MIXER
        value.0 127
        value.1 127
    control.6 {
        comment.count 1
        comment.item.0 DAC
        iface MIXER
        name 'DAC Mux'
        value DAC
    control.7 {
        comment.count 1
        iface MIXER
        name 'ADC Mux'
        value LINE_IN
    control.8 {
        comment.count 1
        iface MIXER
        name ASRC
        value disable
    control.9 {
        comment.count 1
        comment.item.0 off
        comment.item.1 on
        iface MIXER
        value on
    control.10 {
        comment.count 1
        comment.item.0 off
        comment.item.1 on
        iface MIXER
        value on
    control.11 {
        comment.count 1
        comment.item.0 off
        comment.item.1 on
        iface MIXER
        value on
    control.1 {
        comment.count 1
        comment.item.0 off
        comment.item.1 on
        iface MIXER
        value on
3,500 次查看
li-chen
Hi, we also would like to capture the Android system audio on i.MX6. Is there an asound.conf available for i.MX6 platform so that we can use it to capture the Android system audio? Many thanks.
3,500 次查看
RafaelThomasGoz
I have not used mx6 yet, but will. However the alsa-ctl would give you the config options (then you need to transalte them to the asound.conf)
3,500 次查看
li-chen
Hi Rafael,
By alsa-ctl, do you mean tinymix? We have limited experience in setting up the asound.conf. Could you recommend a few links where we should read in order to configure asound.conf properly for capturing the sound on i.MX6? We found this link, http://permalink.gmane.org/gmane.linux.embedded.yocto.meta-freescale/5124, but we don't know exactly what parameters should be changed in order to capture system audio on i.MX6. Any pointer is greatly appreciated. Thanks again!
