Recommended J-Link Model (or Alternatives) for Debugging Cortex-M33 on FRDM-i.MX93
1,255件の閲覧回数
dhruuuu
Hi All,
I’m working with the FRDM-i.MX93 development board and targeting the Cortex-M33 (real-time core). I’ve gone through AN14120 and some community discussions, and I understand that debugging is supported via J-Link over SWD (P14 header).
Just to confirm:
  • Which specific J-Link model would you recommend for FRDM-i.MX93? (e.g., J-Link Base, Plus, Pro, EDU mini, or J-Link Plus Compact).
  • If the compact version works, how is it typically connected and used?
  • Since J-Link is a bit expensive, are there any other debugger options supported for this board ?
Any guidance or recommendations from your experience would be very helpful.
Thanks in advance!
FRDM-i.MX93
2 返答(返信)
1,218件の閲覧回数
Bio_TICFSL
For debugging the Cortex-M33 on an FRDM-i.MX93, a J-Link Base, Plus, or Pro is recommended, as any model supporting the Cortex-M architecture via SWD will work, but the FRDM-i.MX93 requires specific rework to provide 1.8V VREF to the SWD interface. An alternative could be to use the board itself as a remote debug server, potentially with a  , though J-Link is more straightforward for direct debugging.
Recommended J-Link Models
    SEGGER J-Link models
    are a good choice as they are known for their compatibility with Cortex-M processors and support for high download speeds.
    Any J-Link model that supports Cortex-M and SWD debugging
    will work with the FRDM-i.MX93. This includes models like J-Link Base, J-Link Plus, or J-Link Pro.
Important Considerations for the FRDM-i.MX93
  • Board Rework:
    You'll need to perform a specific rework on the FRDM-i.MX93 board to provide the 1.8V VREF voltage to the SWD interface, which is essential for J-Link to function correctly.
    SW Interface:
    The Cortex-M33 on the FRDM-i.MX93 is debugged using the Serial Wire Debug (SWD) interface, which is available on the P14 header.
    Configuration:
    After reworking the board and setting the correct switches (SW1 to 1001 for M33 serial download), you can connect the J-Link and use the
    For debugging the Cortex-M33 on an FRDM-i.MX93, a J-Link Base, Plus, or Pro is recommended, as any model supporting the Cortex-M architecture via SWD will work, but the FRDM-i.MX93 requires specific rework to provide 1.8V VREF to the SWD interface. An alternative could be to use the board itself as a remote debug server, potentially with a  SEGGER J-Link, though J-Link is more straightforward for direct debugging.
1,232件の閲覧回数
gaurav_sharma
@dhruuuu , you can try debugging CM33 on iMX93FRDM using OpenOCD. It uses JTAG over USB so you would not need any external debuggers. Plus it is free and open source. You can have a look at this - Remote debug i.MX93 EVK and i.mx8ulp EVK with openocd - NXP Community
%3CLINGO-SUB%20id%3D%22lingo-sub-2175064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-i.MX93%20%E3%81%A7%20Cortex-M33%20%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8E%A8%E5%A5%A8%20J-Link%20%E3%83%A2%E3%83%87%E3%83%AB%20(%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%A3%E6%9B%BF%E3%83%A2%E3%83%87%E3%83%AB)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20FRDM-i.MX93%20%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81Cortex-M33%20(%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%20%E3%82%B3%E3%82%A2)%20%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82AN14120%20%E3%81%A8%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E8%AD%B0%E8%AB%96%E3%81%AB%E7%9B%AE%E3%82%92%E9%80%9A%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AF%20SWD%20(P14%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC)%20%E7%B5%8C%E7%94%B1%E3%81%AE%20J-Link%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%99%E3%81%8C%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EFRDM-i.MX93%20%E3%81%AB%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%20J-Link%20%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%A7%E3%81%99%E3%81%8B%3F(%E4%BE%8B%3A%20J-Link%20Base%E3%80%81Plus%E3%80%81Pro%E3%80%81EDU%20mini%E3%80%81J-Link%20Plus%20Compact)%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%AF%E3%83%88%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EJ-Link%20%E3%81%AF%E5%B0%91%E3%81%97%E9%AB%98%E4%BE%A1%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%BB%96%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%B5%8C%E9%A8%93%E3%81%8B%E3%82%89%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%84%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FFRDM-i.MX93%2Fpd-p%2FFRDM-iMX93%22%20class%3D%22lia-product-mention%22%20data-product%3D%223701-1%22%20target%3D%22_blank%22%3EFRDM-i.MX93%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Recommended%20J-Link%20Model%20(or%20Alternatives)%20for%20Debugging%20Cortex-M33%20on%20FRDM-i.MX93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-huuid%3D%222257760635729488505%22%3EFRDM-i.MX93%E3%81%A7Cortex-M33%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%20%3CMARK%20class%3D%22QVRyCf%22%3EJ-Link%20Base%E3%80%81Plus%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFPro%3C%2FMARK%3E%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82SWD%E7%B5%8C%E7%94%B1%E3%81%A7Cortex-M%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%81%A9%E3%82%8C%E3%81%A7%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81FRDM-i.MX93%E3%81%A7%E3%81%AF%E3%80%81SWD%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB1.8V%E3%81%AEVREF%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E7%89%B9%E5%88%A5%E3%81%AA%E6%94%B9%E9%80%A0%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%222257760635729488642%22%3E%E4%BB%A3%E6%9B%BF%E6%A1%88%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E8%87%AA%E4%BD%93%E3%82%92%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%3CSPAN%20class%3D%22M5tQyf%22%3E%E3%80%81%3C%2FSPAN%3E%E7%9B%B4%E6%8E%A5%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AFJ-Link%E3%81%AE%E6%96%B9%E3%81%8C%E7%B0%A1%E5%8D%98%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22e6a7757d-e09c-4c3c-a036-0448c27888cf%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%22%20data-hveid%3D%22CAMQAQ%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Qo_EKegQIAxAB%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20uP58nb%22%20data-hveid%3D%22CAwQAQ%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Qo_EKegQIDBAB%22%3E%3CSPAN%20data-huuid%3D%224587136623306621106%22%3E%3CSPAN%20aria-level%3D%222%22%3E%E6%8E%A8%E5%A5%A8J-Link%E3%83%A2%E3%83%87%E3%83%AB%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CA8QAQ%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Qm_YKegQIDxAB%22%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%26nbsp%3B%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3ESEGGER%20J-Link%20%E3%83%A2%E3%83%87%E3%83%AB%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%224587136623306622606%22%3ECortex-M%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A8%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%A8%E9%AB%98%E9%80%9F%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E7%9F%A5%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%89%AF%E3%81%84%E9%81%B8%E6%8A%9E%E8%82%A2%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22e9df9ac7-1c74-40d5-81e0-b6d36dced4eb%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22e9df9ac7-1c74-40d5-81e0-b6d36dced4eb%22%20data-uuids%3D%224587136623306622231%2C4587136623306622606%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CBMQAQ%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Q3fYKegQIExAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%224587136623306623356%22%3E%3CSTRONG%3ECortex-M%E3%81%8A%E3%82%88%E3%81%B3SWD%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8BJ-Link%E3%83%A2%E3%83%87%E3%83%AB%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%224587136623306623731%22%3EFRDM-i.MX93%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%224587136623306624106%22%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81J-Link%20Base%E3%80%81J-Link%20Plus%E3%80%81J-Link%20Pro%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22fc44e956-8349-404f-a082-94c7c6538cfc%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22fc44e956-8349-404f-a082-94c7c6538cfc%22%20data-uuids%3D%224587136623306623356%2C4587136623306623731%2C4587136623306624106%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CBUQAQ%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Q3fYKegQIFRAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20uP58nb%22%20data-hveid%3D%22CB8QAQ%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Qo_EKegQIHxAB%22%3E%3CSPAN%20data-huuid%3D%228841393055300673825%22%3E%3CSPAN%20aria-level%3D%222%22%3EFRDM-i.MX93%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E9%87%8D%E8%A6%81%E3%81%AA%E8%80%83%E6%85%AE%E4%BA%8B%E9%A0%85%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CUL%20data-hveid%3D%22CCEQAQ%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Qm_YKegQIIRAB%22%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%228841393055300675794%22%3E%3CSTRONG%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E6%A7%8B%E7%AF%89%3A%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%228841393055300675085%22%3EJ-Link%20%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%B8%8D%E5%8F%AF%E6%AC%A0%E3%81%AA%201.8V%20VREF%20%E9%9B%BB%E5%9C%A7%E3%82%92%20SWD%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81FRDM-i.MX93%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E7%89%B9%E5%AE%9A%E3%81%AE%E5%86%8D%E4%BD%9C%E6%A5%AD%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22c940ed54-aa32-478e-87db-592538774cd5%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22c940ed54-aa32-478e-87db-592538774cd5%22%20data-uuids%3D%228841393055300675794%2C8841393055300675085%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CCUQAQ%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Q3fYKegQIJRAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%228841393055300673667%22%3E%3CSTRONG%3ESW%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%228841393055300677054%22%3EFRDM-i.MX93%20%E4%B8%8A%E3%81%AE%20Cortex-M33%20%E3%81%AF%E3%80%81P14%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%A7%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%AF%E3%82%A4%E3%83%A4%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20(SWD)%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22001788c0-b340-42cc-98bb-070e61096423%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22001788c0-b340-42cc-98bb-070e61096423%22%20data-uuids%3D%228841393055300673667%2C8841393055300677054%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CCwQAQ%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Q3fYKegQILBAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%228841393055300675636%22%3E%3CSTRONG%3E%E6%A7%8B%E6%88%90%EF%BC%9A%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%228841393055300674927%22%3E%3CSPAN%20data-huuid%3D%228841393055300674927%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%94%B9%E9%80%A0%E3%81%97%E3%81%A6%E6%AD%A3%E3%81%97%E3%81%84%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%EF%BC%88M33%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AFSW1%E3%82%921001%E3%81%AB%E8%A8%AD%E5%AE%9A%EF%BC%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81J-Link%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CP%3E%3CSPAN%20data-huuid%3D%222257760635729488505%22%3EFRDM-i.MX93%E3%81%A7Cortex-M33%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CMARK%20class%3D%22QVRyCf%22%3EJ-Link%20Base%E3%80%81Plus%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFPro%3C%2FMARK%3E%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82SWD%E7%B5%8C%E7%94%B1%E3%81%A7Cortex-M%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%81%A9%E3%82%8C%E3%81%A7%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81FRDM-i.MX93%E3%81%A7%E3%81%AF%E3%80%81SWD%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB1.8V%E3%81%AEVREF%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E7%89%B9%E5%88%A5%E3%81%AA%E6%94%B9%E9%80%A0%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%222257760635729488642%22%3E%E4%BB%A3%E6%9B%BF%E6%A1%88%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E8%87%AA%E4%BD%93%E3%82%92%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%20%3CSPAN%20class%3D%22M5tQyf%22%3ESEGGER%20J-Link%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%3C%2FSPAN%3E%E7%9B%B4%E6%8E%A5%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AFJ-Link%E3%81%AE%E6%96%B9%E3%81%8C%E7%B0%A1%E5%8D%98%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22e6a7757d-e09c-4c3c-a036-0448c27888cf%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22e6a7757d-e09c-4c3c-a036-0448c27888cf%22%20data-uuids%3D%222257760635729488505%2C2257760635729488642%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CAgQAg%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Q3fYKegQICBAC%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%22%20data-hveid%3D%22CAMQAQ%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Qo_EKegQIAxAB%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22a53b6486-0ce1-4c7d-b6da-51e3acefb443%22%20data-uuids%3D%228841393055300675636%2C8841393055300674927%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20qVhvac%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CCcQAg%22%20data-ved%3D%222ahUKEwikyaXbpfSPAxXCLUQIHVD9Hp0Q3fYKegQIJxAC%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22kHtcsd%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Recommended%20J-Link%20Model%20(or%20Alternatives)%20for%20Debugging%20Cortex-M33%20on%20FRDM-i.MX93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255098%22%20target%3D%22_blank%22%3E%40dhruuuu%3C%2FA%3E%20%E3%80%81OpenOCD%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20iMX93FRDM%20%E3%81%A7%20CM33%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82USB%20%E7%B5%8C%E7%94%B1%E3%81%AE%20JTAG%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SO%20%E5%A4%96%E9%83%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E7%84%A1%E6%96%99%E3%81%8B%E3%81%A4%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20-%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-8ULP-i-MX-93-CAS-Training%2FRemote-debug-i-MX93-EVK-and-i-mx8ulp-EVK-with-openocd%2Fta-p%2F1608004%22%20target%3D%22_blank%22%3Eopenocd%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20i.MX93%20EVK%20%E3%81%8A%E3%82%88%E3%81%B3%20i.mx8ulp%20EVK%20%E3%81%AE%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
